Old 2008.03.26, 07:19 AM   #1
Jebroni
Charm City Hustler
Camber Question
Ok.... someone answer me straight here. The difference between Camber, and Degree is?????????? Like is a +2 ti3 rod the same as a 2 degree camber? This **** is mad confusing.
Thanks
Jebroni is offline   Reply With Quote
Old 2008.03.26, 07:41 AM   #2
Flashsp-2
motor guru
Flashsp-2's Avatar
Looking at the top of the car, front toe is like this / \ or \ /. Toe out is when the front tires are pointing outward, and toe in is when the tires are pointing inward, all relative to the front.
Looking at the front of the car camber is like this / \. Nobody ever uses positive camber, only negative, where the tires are pointing in toward the chassis. It's best to find a degree (I use 1.5) that gives you even tire wear over time. Stock cars usually use a little less camber as they have less body roll, mod typically runs a little more due to the extra speed, which creates more body roll, and causes the tires to roll further onto the edge.
Just run a search, there are a ton of threads covering all this stuff, especially the ones written by magic, which are pretty in depth.
Old 2008.03.26, 10:51 PM   #3
try this link...
what is camber and caster?
http://mini-zracer.com/forums/showthread.php?t=27222
also this link...
what is toe in / toe out?
http://mini-zracer.com/forums/showth...953#post295953
hope this helps
Old 2008.03.27, 01:10 AM   #4
DJ Kyosho
The Undertaker
DJ Kyosho's Avatar
Camber and toe are discussed here also.
DJ Kyosho is offline   Reply With Quote
Old 2008.03.27, 01:55 AM   #5
Great links guys. Lots of good information.
Old 2008.03.27, 06:21 AM   #6
Jebroni
Charm City Hustler
Yeah, thanks guys... I appreciate all the help =)
what is camber and caster? herman Setups 1 2008.03.27 10:38 PM
Could anyone print purple question marks for me? Spoon Custom Bodies 3 2006.10.16 10:50 PM
question about camber knuckles and tie rods?? tada Mini-Z AWD MA-010, MA-015 7 2006.07.18 01:02 PM
Camber Question faydoiinspire Mini-Z AWD MA-010, MA-015 12 2006.03.03 09:51 PM
CAMBER ADJUSTMENTS? anyone know of knuckles? PoorZDriver Setups 18 2005.01.08 11:38 PM
