Old 2008.04.29, 09:42 AM   #1
bompie
bompie's Avatar
TGR spinner
HI
I have problems with the setup of the spinner . IŽve manage to get it into setup mode but after that i dont understand if i should press the throttle 2 or 3 times before it come to the brakingprocedure (step5).
i mean is it once for entering the setup, once for middle position, once for throttle, then after that comes the brake.
After the brake (step 5) is the car ready to run or do i have to disconnect the batteries and start again.
bompie
bompie is offline   Reply With Quote
Old 2008.06.26, 05:44 PM   #2
stuZ
mini-z muckraker
stuZ's Avatar
I am having a problem with my spinner esc. I just finished my sinister build, and went to set up my esc with a pn speedy 07 motor. I got it set-up, It worked ok, then it started to cut out. I then tried to set it up again. It was still acting the same. I tried again, and when I powered back up, the esc just flashes at a medium pace. I assume this protect mode, but now I can't get it out of that mode to try to set up a different motor.
might anyone have any ideas?
thanks
stuZ is offline   Reply With Quote
Belt Drive Differential System (BDDS) from TGR Wolf TGR 52 2009.03.12 06:38 PM
Best set up for iwaver 02 M Cherub1m iWaver 99 2009.01.06 07:21 AM
TGR Hurda Challenge UK Jonny Stafford Mini Z Racers England 79 2008.02.01 04:02 PM
fs: TGR Sinister wes Mini-Z Marketplace 15 2008.01.10 11:24 PM
TGR Sinister Chassis and TGR Sinister Pro Chassis Kel Parts and Hop-ups 36 2007.10.11 02:28 AM
