Old 2010.03.24, 12:58 PM   #46
KO PROPO Staff
Eman- We only recommend using the correct module in the correct Tx. Some people may not have a problem, but there is a difference between the modules. This is why we make different module if there needs to be a difference.
Felix2010- Sounds like the solder joints for the module pins inside the Tx may be damaged and not the antenna. Most likely it is the solder joint that goes from the module pin and the PCB trace goes to the antenna mount.
Old 2010.03.31, 02:16 PM   #47
Eman
Eman's Avatar
Thanks for responding. I received the correct module and all is good. I have another question. What is Advanced HSR and Super HSR? Is this the speed the transmitter send commands to the receiver?
Photos
"Necessity is the mother of all invention"
Eman is offline   Reply With Quote
Old 2010.03.31, 06:45 PM   #48
KO PROPO Staff
Yes these are the speeds that the transmitter sends the commands to the receiver. You have to use the correct response for the board (Mini-Z) that you are using. You can find the chart for the chassis and responses here.
Advanced HSR is the fastest response in the Helios, switch in H position and 2 channel setting. (8.0ms)
Super HSR is the next fastest response, switch in the H position and 3 channel setting. (11.0ms)
Normal response, switch in the N position (down). (16.0ms)
Old 2010.04.04, 10:14 AM   #49
Steve B.
Hi There,
New to Mini Z but not new to RC. I am trying to find the exact part numbers for the items needed to use my 3PK with the MR-03. It looks like you only need two items. The module adapter and the module, i think that is correct. If somebody could please post the correct module part number.....that would be awesome!!!
Thanks
Steve
Steve B. is offline   Reply With Quote
Old 2010.04.04, 05:37 PM   #50
ScoobyPete
ScoobyPete's Avatar
Hi there
I'm looking for an EX-10 Helios or EX-10 Eurus, and the 2.4ghz Mini z module I think its the RF901sm for the Helios or 902sm for Eurus, I'm based in the UK so do you have a UK distributor or where is the best place to purchase internationaly from?
http://www.wlmr.co.uk
Old 2010.04.09, 12:19 PM   #51
KO PROPO Staff
Originally Posted by ScoobyPete View Post
Hi there
The Helios has been discontinued and replaced with the Eurus. Either the RF-901SM or RF-902SM will work with the Eurus, but the 902SM would give you better response.
RC Disco is the UK distributor and you can order from them.
Old 2010.04.10, 04:50 AM   #52
ScoobyPete
ScoobyPete's Avatar
Thanks for the info
Old 2010.04.10, 11:29 AM   #53
mk2kompressor
at the Bleeding Edge
mk2kompressor's Avatar
just a shame they dont know what a mini z module is
also the problem is the fact the 902 dont work with the helios
Team B.E.R.T
MR02/3 eating MA010
MR-03
HFAY S9 F1 Winner
Sinister V1
MRCG Prototype
MRCG 1.0
Bleeding Edge Racing UK
Old 2010.04.13, 04:47 AM   #54
pedrocamp
Ain'tSoldEm
I have a EX1-UR with a drop down kit which is getting stuck when I select SETUP on the MENU. I can't adjust any settings or get out of SETUP unless I turn the radio off. Any ideas? TX board or drop down kit issue? Thanks...
High Speed Hobbies
Old 2010.04.13, 03:18 PM   #55
lfisminiz
lfisminiz's Avatar
Hi Pedro....my EX was doing different things like that. I sent it back. They put a new board in. They will take care of you.
Old 2010.04.13, 03:22 PM   #56
pedrocamp
Ain'tSoldEm
Thanks Larry. They gave me excellent service with a module problem I had a while back. Just hate to be without my radio!
High Speed Hobbies
Old 2010.04.13, 03:58 PM   #57
lfisminiz
lfisminiz's Avatar
PEDRO...i know what you mean...but i always have my trusty Helios, which i always liked as much or better. Now im tinkering with the EURUS. If a radio goes down...i have a spare or so.
Old 2010.05.10, 09:57 PM   #58
leonen
Scuderia Leone Racing
leonen's Avatar
Send a message via MSN to leonen
20-30C Discharge Lipo... is it safe?
I just got a Turnigy 2.2 Lipo 3 cell, 20-30C discharge battery.
Now, is it safe to use on my KO-Propo Ex-10 Helios? Won't the high discharge damage the radio or the module?
Thanks!
Néstor Leone
Buenos Aires, Argentina.
Http://www CircuitoZur.com.ar/
Http://www.ScuderiaLeoneRacing com.ar/
leonen is offline   Reply With Quote
Old 2010.05.10, 10:55 PM   #59
Action B
The Galliant Dude
Thanks!
Doesn't work like that! Discharge rate is the maximum possible current that can be drawn. The battery will only put out the amount of amperage that your device requires so there is no danger in having a higher discharging battery.
Action B is offline   Reply With Quote
Old 2010.05.11, 07:43 AM   #60
leonen
leonen's Avatar
Thanks ActionB!... I had several friends who blew their modules, and word has it that it was because of the Lipos'.
Just checking.
Néstor Leone
Ko Propo EX-10: A few simple questions Programmers Transmitters, Receivers and Crystals 9 2008.04.09 07:01 AM
SSMT Questions cunnibra Mini-Z Monster MM-01 22 2006.02.08 01:40 PM
