Old 2008.11.16, 02:17 PM   #1
Jace1283
CCMMMK
Jace1283's Avatar
Contemplating getting 2.4ghz
hi
im running stock radio with my mr02 and ive been pretty competitive but im wondering if the 2.4 will make my car and ability to control it better. Has anyone got the 2.4 and not seen an improvement or is it pretty much a given that 2.4 will be faster. what differences did you notice when you upgraded
thanks
My 1/28s: MR-03, MR-02, MA-010, F1, Overlands, Monsters, Xmod Servo Crawler, Xmod cars very modded
My VIDEOS: http://www.youtube.com/user/Jace1283xmod
Jace1283 is offline   Reply With Quote
Old 2008.11.16, 09:01 PM   #2
byebye
byebye's Avatar
You'll definately notice a difference going from AM to 2.4ghz. The car has no twitch and responds much quicker. The only gripe most people have but get over is the reverse. It takes some getting used to but once you learn it's pretty easy and I hardly notice the difference.
When I go back and forth I realize just how quick the response is with 2.4ghz. And no antenna!
Kris
Old 2008.11.16, 11:12 PM   #3
hi jace1283
i suggest that you try one out... to feel the difference for yourself...
i wrote a review a while back... hope this helps
http://mini-zracer.com/forums/showth...ghz+asf+review
http://shop.tinyrc.com/product.php?productid=19022
Old 2008.11.23, 12:23 PM   #4
Jace1283
CCMMMK
Jace1283's Avatar
thanks for responses. i ended up getting it and racing it this weekend. its great exept for the reverse driving me absolutely crazy. i read the whole thread, i guess i just have to get used to it. i think its retarded though, when i put it in reverse, go in reverse! why did they mess with that, im not gonna brake! love the no big antenna thing on the car and controller. the power supply post work great now too so i can plug the transponder into it. that lets me ditch the batteries taped in my roof
Old 2009.01.04, 02:11 PM   #5
Jace1283
CCMMMK
Jace1283's Avatar
so i've had 2.4 (kyosho controller) for a while now and i hate it. the reverse just sucks, you loose so much time. it's just not easy enough or consistent enough to be any good. also i cant put drag brake in because then it won't go in revers at all! also idk if its nimh im using or what but the controller dies on me after 5-6 races even with charged batteries. its like no product testing was done with this junk, use your freaking brain and some common sense. junk. some times i drive forward to bounce off a wall after a crash because thats faster than reverse but still slow. i get in far more crashed and of more severity because i dont know when it will go in reverse. one time another guy running it couldn't get it to go into reverse fast enough on the straight and he got whacked hard. his body fell off and lost the race. had he been running am he would have had plenty of time to reverse and get out of there. trash
Old 2009.01.04, 02:17 PM   #6
briankstan
SLMZ / HFAY
briankstan's Avatar
Jace, what controller are you using? If you have the EX-10 helios with 2.4 module I can help you set it up so the reverse won't bother you again.
I to had the same issue when moving to 2.4ghz so I know were you are coming from.
Old 2009.01.04, 02:19 PM   #7
Jace1283
CCMMMK
Jace1283's Avatar
no its the kyosho junk, i might get the helios sometime because this controller makes racing unpleasant
Old 2009.01.04, 02:22 PM   #8
briankstan
SLMZ / HFAY
briankstan's Avatar
I felt the same way. I didn't like the KT-18, and the reverse would make is so I'd rather drive my AM car. Now that I have everything setup and working with my helios, I've actually converted all my cars, Racer, F1, Overland and my Pan Car to 2.4 now and I love it.
Old 2009.01.04, 02:28 PM   #9
Jace1283
CCMMMK
Jace1283's Avatar
thanks for the input, im usually stingy with spending money on mini-zs but i think i might order a helios tomorrow($280!), thats how frustrated i am, lol
can the helios do drag brake? my car rolls far to easily with kt18
Old 2009.01.04, 02:53 PM   #10
briankstan
SLMZ / HFAY
briankstan's Avatar
you can setup the drag brake, Look for a used helios with module, check ebay you'll be able to find one cheaper.
I've picked up a used one for $100, then you just need the 2.4 module.
Old 2009.01.04, 04:21 PM   #11
Skv012a
Skv012a's Avatar
Honestly, you lose .5-1 second to the AM when using reverse. As far as I know, Helios won't help that either since thats how the car boards are designed. As far as battery life, I've used mine for probably 6 hours and it still works fine. Contact Kyosho and see if they might replace it for you or try higher cap batteries. Maybe hybrids due to their low idle discharge rate.
New site.
Old 2009.01.04, 04:28 PM   #12
soulstice
soulstice's Avatar
Hey Brian,
Mind sharing the setting you have for reverse on your Helios. I'd like to try it out.
My Lego Habit: FoundryDX
Old 2009.01.04, 04:50 PM   #13
briankstan
SLMZ / HFAY
briankstan's Avatar
Originally Posted by soulstice View Post
Hey Brian,
see my post here. http://www.saltlakemini-z.com/forum/...hp?topic=198.0
the trick is to set the ABS so you just hold the reverse on, then the ABS will wait the appropriate amount of time then kick in the reverse. it works really well and you don't have to worry about waiting and acting to fast, the waiting again.
Give it a try.
Old 2009.01.04, 11:55 PM   #14
Skv012a
Skv012a's Avatar
So that minimizes the time it takes to reverse via TX, interesting.
New site.
Old 2009.01.05, 12:03 AM   #15
briankstan
SLMZ / HFAY
briankstan's Avatar
it doesn't remove the delay, but you set the controller to wait for the time, this way you aren't fighting it. because if you act to fast you have to wait again, and if you wait to long, well that just more time lost too.
I've had great sucess with it.
my 2.4ghz / kt-18 review.... herman 2.4GHz ASF System (Auto Selected Frequency) 45 2017.11.28 03:56 AM
FS: Kyosho Perfex KT18 2.4Ghz ASF Controller - Barely Used limbohz Mini-Z Marketplace 1 2008.07.31 11:25 AM
***NEW PRODUCT*** 2.4Ghz MR-02LM LeMans Series Tim Johnson Kyosho 75 2008.01.25 06:23 AM
Kyosho Mini-Z MR-02 LM 2.4GHz ASF Pre-Order arch2b Mini-ZRacer.com Announcements 0 2008.01.20 06:02 PM
New for 2008: MR02LM and 2.4Ghz Radio System mini-z Mini-ZRacer.com Announcements 0 2007.10.16 06:24 PM
