Old 2008.12.09, 12:05 PM   #1
KO PROPO Staff
2.4GHz Tx Settings
It has been brought to my attention that when using the 2.4GHz module you must have the following settings in your Tx.
1. Steering Travel Max 70
2. Steering Balance Max 70%
3. Throttle High Point Max 60
4. Throttle Brake Max 60
5. Quick ST & TH in the EX-1 UR cannot be used.
Setting your Tx above the max settings may cause the vehicle to operate incorrectly.
For example, recently we have ad a few customers say their car will not go into reverse. If the throttle settings are not set to the above settings, yes it will not go into reverse because the max endpoint settings for the ESC will get goofed-up. Some modules may get away with it, but most will not operate correctly.
Please check your settings. I have found that with the above settings, the cars do respond better.
Old 2008.12.09, 02:10 PM   #2
mikey
Send a message via AIM to mikey
as i switched over to 2.4, i set up a template for all those exact settings on my ex10.
although, now, i noticed that my F1 that is still AM isnt working correctly. lol.
mikey is offline   Reply With Quote
Old 2008.12.15, 12:34 PM   #3
Felix2010
Thank you
Thank you KO for posting this info. It appears to have resolved my "signal loss" and "glitching" problems I've been having (For now, let's hope it's permanent. )
If any other developments arise concerning the use of the RF901-SM 2.4ghz module for Mini-Z when used with the EX-10 Helios or the EX-1UR I would very much appreciate any and all updates.
Thanks again for your help!
- Lawrence
Old 2009.01.17, 10:32 AM   #4
Darth_Hell
Ko Porpo
Hi, THANK YOU KO for the above... Currently my settings are all to the max!!! I thought if all is max, then my car will be also maxed out.
Yet to try out your recommendations... By the way, your recommendations are they relevant to all KO TX all around your productions? What i mean is different batches of electronics will differ slightly, so your recommendations are they fit for all KO TX???
Darth_Hell is offline   Reply With Quote
Old 2009.01.19, 07:43 PM   #5
KO PROPO Staff
The settings listed are for all KO Tx's that you want to use with the 2.4GHz Mini-Z.
Old 2009.01.20, 01:22 PM   #6
Darth_Hell
Cheers KO!!!
Thanks so much... The information really help a lot!!! Maybe KO should print the info and should be accompanied with the kit!!!
Old 2009.01.20, 02:39 PM   #7
2EZ
Mini Z Driver!
2EZ's Avatar
Send a message via AIM to 2EZ
Does this apply to the Helios or just the the EX-1 UR ??
Thanks
2EZ
2EZ is offline   Reply With Quote
Old 2009.01.20, 05:07 PM   #8
hrdrvr
hrdrvr's Avatar
^ Its for the helios too 2EZ. Ive got a copy of it printed and waiting for you at the track for tommorrow
Landon
LET's Go Racing!
Old 2009.07.01, 10:42 AM   #9
tongho
All my 2.4 mini Zs works far more better now. Can go reverse like normal AM board mini Z.
Mini Z AWD 2.4 Ghz
Mini Z F1 2.4Ghz
Mini Z Monster 2.4 Ghz
tongho is offline   Reply With Quote
Old 2009.12.03, 08:34 PM   #10
lfisminiz
lfisminiz's Avatar
Mr-03 board
Do these setting apply to the MR-03 boards since there different than the MR-02 boards.
THANKS
Old 2009.12.04, 08:08 PM   #11
KO PROPO Staff
THANKS
Tx settings do apply to the MR-03 as well.
Old 2009.12.04, 08:51 PM   #12
lfisminiz
lfisminiz's Avatar
Thanks for both quick replies.
Old 2010.01.20, 11:48 AM   #13
racer_18x
question for Ko Propo Staff
hi i've notice that everywhere has no stock on the rf 901sm module and ko has recently produce the new rf 902sm module. can this rf 902sm module work with the older tx eg. ex1 or ex1ur?
racer_18x is offline   Reply With Quote
Old 2010.01.21, 11:09 AM   #14
KO PROPO Staff
The 901SM module has been out of stock for a while. They should be in stock once again by next week.
The 902SM will only work with the new EX-10 eurus.
Old 2010.01.21, 11:31 AM   #15
racer_18x
so that means those other tx eg. m11 or 3pk wont be able to use the rf 902sm as well? cause the previous modules work on those tx with the usage of the pn converter
FS: Kyosho Perfex KT18 2.4Ghz ASF Controller - Barely Used limbohz Mini-Z Marketplace 1 2008.07.31 10:25 AM
***NEW PRODUCT*** 2.4Ghz MR-02LM LeMans Series Tim Johnson Kyosho 75 2008.01.25 05:23 AM
Kyosho Mini-Z MR-02 LM 2.4GHz ASF Pre-Order arch2b Mini-ZRacer.com Announcements 0 2008.01.20 05:02 PM
2.4Ghz AFS System Tim Johnson 2.4GHz ASF System (Auto Selected Frequency) 0 2007.10.16 05:45 PM
New for 2008: MR02LM and 2.4Ghz Radio System mini-z Mini-ZRacer.com Announcements 0 2007.10.16 05:24 PM
