Old 2008.12.20, 06:46 PM   #1
okoye
Guest
Posts: n/a
Overland Adjustable suspension
adjustable shocks they are so awesome!!
it seems that you can adjust the height..lower for a bagged look and higher for that offroad look
Old 2008.12.21, 02:40 AM   #2
You can adjust preload, which will essentially lower and raise the truck. However, if you "lower" the car by reducing the preload, you will have more droop, which is something you must account for.
I preferred to lower the OL by putting a couple shims between the shock tower and the chassis. And the same amount of shims on the ball studs that go to the link rods to keep the geometry the same.
Old 2008.12.21, 12:26 PM   #3
okoye
Guest
Posts: n/a
it definetly makes buying the oiled shocks seem like it isnt worth the buy
Old 2009.06.27, 10:23 AM   #4
dub599
these will go great on my overland once i find one to buy
dub599 is offline   Reply With Quote
Old 2009.06.27, 10:27 AM   #5
okoye
Guest
Posts: n/a
just look on the bay idk if they still ahve them though
XMod Generation 1- Rear Right Suspension Binding Flat 4 Racing Xmods 5 2007.03.07 10:44 PM
LSSM Suspension too soft???? RedRSX Mini-Z Overland MV-01 18 2004.08.02 05:41 PM
Sticky front suspension chelboed Mini-Z Overland MV-01 3 2003.07.15 06:32 PM
Bodies, Suspension, Tires? mlepage Parts and Hop-ups 26 2003.03.11 09:40 PM
Suspension setup tip butler Setups 9 2002.02.01 03:02 AM
