Old 2010.09.09, 05:14 PM   #61
banquer
banquer's Avatar
Another question.
I think the 4PK are sending signals with 901SM module and Futaba FASST module simultanously, isn't it?
The anntena wire of the KO module, where do you put it? With the FASST one?
King regards from Spain and thank you very much to share your work with us!!
Club Deportivo Micro RC Granada
http://www microrcgranada com
Futaba 4PK and KO901SM inside!
Kyosho MR03 Ferrari F430
Kyosho MR03 Mercedes C9
banquer is offline   Reply With Quote
Old 2010.09.24, 01:39 AM   #62
doramider7
Originally Posted by CCL View Post
Ha ! '
I knew you very well
Hello all,
i believe that 4PK will work with 2.4 ASF. I have a 3PJ ( previous to 3PK ) and it works , and its known to work with 3PK .
All you need is that PN racing adapter shown few posts before and the Ko-Propo Mini-Z module . Ko propo module goes on adapter and adapter on Transmitter. easy ! my dnano goes like that . Good Racing all !
doramider7 is offline   Reply With Quote
Old 2010.09.28, 11:57 PM   #63
banquer
banquer's Avatar
Thanks for sharing the info
Thank you very much wikedgmc. Today I'd received mine 4PK and after an hour of work to fit the 901SM module all is done ant works fine.
King regards from Spain.
Old 2010.09.29, 02:20 AM   #64
Felix2010
I would like your opinion on how difficult this modification is to figure out - How to install 901-SM Mini-Z module into a 4PK?
I am coming from KO transmitters (Helios + EX1UR) and am thinking about trying Futaba. The 4PK, to modify it for 2.4 Mini-Z use, am I correct in that all that needs to be done is:
1. Disassemble 4PK.
2. Disassemble Mini-Z RF-901SM MIni-Z module.
3. Connect the 901SM's circuit board to the correct pins on one of the 4PK's PCB's.
Question here: Does any Module" boards need to be removed from the internals of the 4PK? Or am I simply "adding another module" to the 4PK by connecting the pins on each together, without taking any boards/anything at all out of the 4PK?
4. Reassemble.
I am not an electronics expert and am average with a soldering iron. What are my odds of figuring this mod out and getting my 4PK to work correctly 100% with both the Mini-Z 2.4 ASF and still also work 100% with Futaba FASST Rx's?
ANy more pics/advice would be greatly appreciated. Thanks to all who share all this good info!
*** TOP SECRET MOTORS ***
[FONT="Book Antiqua"]
Old 2010.09.29, 04:49 AM   #65
kaka
Originally Posted by wikedgmc View Post
AS promised everyone. Looks like a module based controller still just the module is inside. I am pretty sure that you use the display only setting to power the mini-z and I know the one I saw here the bind button and led were moved under the left side cap. When I get to Fast Pace Racing today I will play with it some more.
Anyone with thoughts or ideas chime in here. I love the feel of this radio so much more than the feel of the 3PK.
Would you plz share which pins goes to ASF pins ?
kaka is offline   Reply With Quote
Old 2010.09.30, 06:11 PM   #66
banquer
banquer's Avatar
Not at all. No module needs to be removed. When you start the 4PK in DISP mode, Ko propo are working, if you start 4PK with normal on (radio mode), Ko module don't work and the futaba 2.4 FASST are working.
This is the way I connect 901SM module inside 4PK.
Hope this helps!
And this is the way I'd done to pair module and miniZ. This way can backup your 4PK to it's original state, and don't need to do drills on the 4PK.
Don't forget to remove the 901SM led.
The KO antena wire is not conected to the 4PK inside antena. Simply put it inside the 4PK, not attached to anything.
King regards from Granada (Spain).
Old 2010.09.30, 06:13 PM   #67
banquer
banquer's Avatar
Use my photos and put attention on colored wires.
Cheers!
Old 2010.09.30, 09:56 PM   #68
yscheong
Originally Posted by banquer View Post
This is the way I connect 902SM module inside 4PK.
Sorry, is 901sm or 902sm in the 4pk?
yscheong is offline   Reply With Quote
Old 2010.09.30, 10:54 PM   #69
kaka
Cheers!
I'd like to confirm :
1. The "black" and the "green" 're sockets are'nt they?
2. We have to disconnect the led to turn ASF on and connect it to FASST mode. So we don't have to press the "pairing botton" in ASF module ?
Thak's you very much for your sharing. I'm very appreciated for it.
Old 2010.10.01, 01:40 AM   #70
banquer
banquer's Avatar
Sorry, is the 901SM.
Old 2010.10.01, 10:39 AM   #71
banquer
banquer's Avatar
I don't understand. Can you explain it?
No.
You must disconnect the led to do the 901SM more thickness and can be inserted into the 4PK more easy.
The paring switch are the green and red wires in the left side of the 4PK. To put 901SM into paring mode, you must to plug the pin, wait five secods, and unplug it.
Regards.
Old 2010.10.03, 09:45 PM   #72
kaka
No.
Regards.
Sorry. it's my english...I mean a connector.
I was in my office when I read it, so I was confused...but now It's clear & once again....thank you so much, now I can play my ASF mini-z with my 4 PK.
Old 2010.10.04, 11:24 AM   #73
john-lam
Clarify Point
No.
Regards.
Hi:
thank you for your vulable information to modify the 4pk to suit mini z system
however i have two things need your help.
1) you mean disconnect the led, it means the led should be taken out from the 901sm pcb board?
2) During paring with the mini z car, Should i need to hold the pairing button
on the car PCB board and at the same time connect the pin on the 4pk for five seconds and then disconnect it
it would be appreciated if you can help me clarify these two things
thanks one more time
john-lam is offline   Reply With Quote
Old 2010.10.04, 12:25 PM   #74
banquer
banquer's Avatar
Originally Posted by john-lam View Post
Hi:
Yes, thats right!
In this order.
1st. plug red and green wires from 4PK.
2nd. Turn on the 4PK.
3rd. Count five seconds.
4th. Unplug red and green wires.
Now the the 4PK is in 901SM paring mode.
Turn the miniz on with the pairing switch on. When miniz led goes on, release switch. Led must be on. If wright then turn off the miniz and the 4pk. If not repeat the proccess.
Dont forget to put 4PK in normal mode and C1 emission mode. And turn on to DISP mode (this is the mode that the 901SM run).
They are sincronized!
King regards!
Old 2010.10.04, 04:27 PM   #75
Felix2010
Thank you so much for all the detailed information! I know taking pics and explaining things take time and effort and I appreciate all he effort you put into doing this tutorial for us. Great job!
Preliminary testing and thoughts for using 2.4G module with EX1UR + 2.4G AWD Aurora 2.4GHz ASF System (Auto Selected Frequency) 9 2008.05.26 03:51 AM
2.4G ASF MR02LM vs MR02 (pictures) Aurora 2.4GHz ASF System (Auto Selected Frequency) 7 2008.02.17 10:18 AM
