Go Back   Mini-ZRacer.com Forums > Mini RC
Old 2011.03.01, 01:27 AM   #241
thanks for the info... and cool site...
have you seen my mini-z 206 wrc collection? if not, click below to see my cars...
Old 2011.03.01, 12:22 PM   #242
vigilanterc
Yes I did! that is why I mentioned my love for the car. One of the coolest WRC Cars of all time. Radical yet functional and Beautiful!
Nice work on those. I am envious of them.
Steven
vigilanterc is offline   Reply With Quote
Old 2011.03.01, 01:42 PM   #243
Skv012a
Skv012a's Avatar
I re-ordered from Omni since they have em in stock AND emailed me about 10$ off 100$ order. Hello 2 day shipping
Also remembered how I even know Omni- got my first 1/43 Modifiers factory box from them years ago and I loved those lil ricer models. So 2 birds from one store, not bad at all.
New site.
Old 2011.03.01, 02:58 PM   #244
Traveler
of both Time and Space
Traveler's Avatar
Can anyone confirm whether or not these cars use 130 size motors?
Old 2011.03.01, 03:44 PM   #245
Skv012a
Skv012a's Avatar
They do NOT as was answered previously, but we may be able to modify them to.
New site.
Old 2011.03.01, 05:17 PM   #246
vigilanterc
If a motor used is larger than the stock one you will run the risk of killing the board.
Old 2011.03.01, 05:25 PM   #247
ChiMiniRc
The instructions have the speed control rated at 7 amps. It does not list the max voltage. I couldn't find an online manual to share but it is listed in the back. That should be enough to handle a pretty hot motor. What I don't know is if 7 amps is peak or sustained. Also 7amps may be instant death but 2 amps after 5 minutes might be death by heat. Dunno.
I would think you could run a bigger motor for a few minutes and monitor temparature.
Old 2011.03.01, 05:29 PM   #248
vigilanterc
That is good to know. I did not read the specs on the ESC. I would assume 7amp max continuous? Most Escs are rated that way and usually have a MAX Amp for a short burst.....I think the car needs to be WIDER before it gets too much faster..............I am working on converting one into a wide chassis style to fit one of my wide slot cars......The front is easy the rear will need more work to make a longer shaft or wider wheel adaptors......
Here is a pic of the cars I want to convert with a WIDE chassis layout..
Any thoughts on this concept?
Steven
Vigilante R/C
Old 2011.03.01, 05:37 PM   #249
ChiMiniRc
I know with different, larger scale 1:28 prototype car I saw at iHobby, it had a 130 size or larger motor, it was AWD, and was getting plenty enough power from a Lithium power setup. That speed control was rated for 5 amps. So if 7 amps is continous, nearly any motor that isn't insane should work. At least long enough to monitor temps without worry about instant blowout.
Old 2011.03.01, 05:43 PM   #250
vigilanterc
[Deleted from post.
Old 2011.03.01, 05:44 PM   #251
Traveler
Traveler's Avatar
Thanks! Looked through the thread but didn't see this.
I know with the prototype car I saw at iHobby, it had a 130 size or larger motor, it AWD, and was getting plenty enough power from a Lithium power setup.
Huh? Tell us more please . Are you referring to the chassis in the first picture in post #1 or something else. I didn't think these were capable of being converted to AWD.
Old 2011.03.01, 05:46 PM   #252
vigilanterc
I think he was mentioning another car that had similar specs.
This car is not going to be offered in 4WD as a conversion as far as I know.
It was just a comparo of specs to say that this car may be able to have a motor with more grunt without killing itself!!
Old 2011.03.01, 05:49 PM   #253
ChiMiniRc
Sorry, I edited the post a little to clarify.
There was a 1:28 scale prototype car at ihobby. It was NOT HPI. It was a larger, heavier, car with AWD and lithium power. The reason I shared the info is that the car only had a 5 amp speed control. SO if a heavier car with a bigger motor than the rs32 can do fine with 5 amp, the rs32 should be fine with the 7amp controller it has included.
This is the 1:28 prototype I'm referring to.
Old 2011.03.01, 05:49 PM   #254
Traveler
Traveler's Avatar
Ahhh! Thanks for clearing that up.
Old 2011.03.01, 08:55 PM   #255
vigilanterc
Here is the next challenge. The Mclaren body is wider than the chassis. The body is 63mm and the chassis is 54mm. I need to make a Wide stance kit and fit it under this awesome looking body.
Without a doubt it will handle better than stock. I plan on using the slot car rims and tires so the gear ratio will be a little taller so the speed will pick up.
Custom adapters will need to be made and perhaps a new chassis all together maybe if I need to. Will try to lengthen the wheelbase as needed as well.....Lots of work, but man is it fun!
Cant wait to get started!!!
I will post more pics as I progress.
Steven
Vigilante R/C
Futaba 1/20 Scale Indy Cars Mondo Mini RC 54 2006.05.12 09:35 PM
1/32 wws cars.... herman Mini RC 12 2004.08.27 11:47 AM
Tom Thumb Hobbies -- Race Report 12/13/2003 latency Tom Thumb Hobbies, Columbus OH 0 2003.12.14 01:23 PM
1:1 scale cars RallyNut Off-Topic 71 2002.06.08 02:07 AM
All my small scale RC Cars with Clod Buster ricerocketinwa Autoscales, Bodies, Cars and Drivers 4 2002.05.23 08:02 PM
