Old 2009.07.20, 08:07 AM   #31
MikeL
Painter Guy
MikeL's Avatar
Originally Posted by Davey G View Post
My only complaint is that the horsepower was way down on the ASF compared to the bigger 18th scale electronics.
Your Fet stack (or lack of) is weak
2.4 MR02 WTF, MH Spec tube damper
2.4 MR02 Std front end, MH Spec tube damper
http://www.MikeLdesigns.com
http://www.majsrc.com
http://www.nyrcsuperraceway.com/
MikeL is offline   Reply With Quote
Old 2009.07.21, 06:50 AM   #32
Felix2010
I ran the tekin b1r due to its size and power. This esc can even handle 4 cells on a 540 type motor. The esc is a Spektrum sr3100, the pics show otherwise but the Spektrum is what I use. There is a new super micro spektrum reciever now too. Talk to you soon!
Thank you for the info Dave!
Old 2009.07.21, 11:46 AM   #33
Just noticed, Dave -- why is there a power switch on your car? Removing that should help a bit with the horsepower problem, as well as an FET stack.
Old 2009.07.27, 09:57 AM   #34
Davey G
Need a mini z Painted????
Davey G's Avatar
I have removed my switch on other boards and felt no difference even though others say otherwise. I ended up qual 2nd and finishing 2nd this past weekend at the PNWC at Maj;s hobby shop. THe only person to go faster then I was Chad Nelson. I made an attempt to thin out the side flex plates and ruined them. In the 3rd round and the main I ran an mr02 and was way way slower. I look forward to more testing. Brian...U got mail!!
Dave Graboski
DG Designs
Old 2009.07.27, 11:06 AM   #35
tudor_47
tudor_47's Avatar
Out of curiosity, what damper is you are using? Looks like a Kyosho but it is black?? If Kyosho do you have a part number?
/Johnny
Get a P28
Old 2009.07.27, 12:11 PM   #36
MikeL
Painter Guy
MikeL's Avatar
That's sharpie special edition
Old 2009.07.27, 12:32 PM   #37
Davey G
Davey G's Avatar
Old skool PN.
Dave Graboski
DG Designs
Old 2009.07.27, 12:55 PM   #38
MikeL
Painter Guy
MikeL's Avatar
Old skool PN.
or that
Old 2009.07.28, 12:54 AM   #39
The oil shock is a Kyosho, dyed black.
Old 2010.01.02, 10:58 AM   #40
JuniorWKR
White Knuckle Racing
JuniorWKR's Avatar
my 1.1.... still a bit of work in progress but so far its ok... not totally happy with the servo and i have a slight chatter in the rear... but it is pretty amazing how well this setup puts power to the ground for being so lite...
Junior
Old 2010.01.02, 05:36 PM   #41
skyler
skyler's Avatar
Junior, Your car looks great!
Old 2010.01.03, 03:53 AM   #42
Looks great, Junior. How is that exposed servo motor working out for you? I've always been worried about dust so I capped my servos back after soldering the wires to them. If you're having servo troubles I'd definitely look for dust inside the casing.
As for the chatter issue, try a stiffer pair of disk damper springs and/or shim the springs to increase damping. The MRCG1.1 has higher roll resistance than normal Mini-Z's so you need to increase damping correspondingly to avoid chatter.
Old 2010.01.03, 02:56 PM   #43
JuniorWKR
JuniorWKR's Avatar
solved the rear chatter with the heavier dampner springs... thank you...
the servo is siliconed so no dust gets in.... my problem with the servo is its inconsistency with recentering true every time... i hope someone can come out with a mr03 servo setup... hint... hint...
Junior
Old 2010.01.03, 03:20 PM   #44
I hear you loud and clear.
Old 2010.01.03, 04:27 PM   #45
JuniorWKR
JuniorWKR's Avatar
do you guys over a stiffer top plate for the batteries?... i believe with the soft one we are forced to crank it down harder and may be causing the chassis to twist.....
Junior
MZR Exclusive: GSR MRCG1.1 First Look color01 GSR 54 2009.06.12 04:45 PM
