Old 2009.06.13, 07:09 PM   #1
minittrackmann
minittrackmann's Avatar
My MRCG
Just waiting on the servo... Ordered the Futaba S3113.
Installed are the Associted XPS decased and a Futaba AM reciever. Its pretty large but I fit everything in pretty good.
minittrackmann is offline   Reply With Quote
Old 2009.06.13, 09:09 PM   #2
Scrapper
Stu
Scrapper's Avatar
Send a message via MSN to Scrapper
thats awesome cody
Swaggerific Boss Status
Scrapper is offline   Reply With Quote
Old 2009.06.13, 09:09 PM   #3
ianc
ianc's Avatar
Post a few more; can't see much.
Use the macro feature on your camera,
ianc
Old 2009.06.13, 09:35 PM   #4
minittrackmann
I just got the camera, and I have no idea were to use the Macro feature..
Cody
Old 2009.06.13, 09:45 PM   #5
minittrackmann
Little better quality
Old 2009.06.14, 12:47 AM   #6
ianc
ianc's Avatar
Thanks for the pics; I'm building mine as we speak and your pics are helpful.
Much better results this time!
ianc
Old 2009.06.14, 08:55 AM   #7
minittrackmann
Cool. Glad to be of help!
Old 2009.06.14, 09:19 AM   #8
Scrapper
Stu
Scrapper's Avatar
friggin sweet
Old 2009.06.14, 04:14 PM   #9
Looks nice, Cody. Do you have enough clearance for the disk damper? The ESC looks dangerously close.
Old 2009.06.14, 05:12 PM   #10
minittrackmann
Yessir...
Put the esc as close as I could without the disk damper hitting..
Very nice kit, fit and finish is next to none!
Cody
Old 2009.06.16, 10:35 PM   #11
thunter
would you happen to know if the new double a arm set would fit if so im down to buy it
thunter is offline   Reply With Quote
Old 2009.06.16, 11:07 PM   #12
ianc
ianc's Avatar
Brian,
If you're reading this, would it be helpful for Cody to put shims under his side rails where they attach to the main chassis for imroved 'rear steer'?
Just curious; the docs make it seem like it would be a good thing to do, even on a 1.0.
And Cody,
Can you post some closer pics of your servo and ball linkage installation? Part #'s? Thanks,
ianc
Old 2009.06.17, 12:22 AM   #13
Yes, the rear steer spacers are good on both 1.0 and 1.1 cars for the vast majority of track layouts. On the original MRCG, though, you have to watch out that the center spring mount is long enough to compensate for raising the flex plates. Otherwise you can run into a low ride height problem in the middle of the chassis.
I took the pictures for converting the Futaba S3114 for ASF board usage; they'll be up in a bit.
Old 2009.06.17, 09:51 AM   #14
ianc
ianc's Avatar
Excellent! I've got a brand new AWD ASF board and S3114 sitting on my bench at home just waiting! Thanks,
ianc
Old 2009.06.17, 04:54 PM   #15
Missed this post...
The double A-arm set should fit the MRCG and MRCG1.1 with a bit of work. The front mounting holes on that front end fit on the MRCG front end just like mounting an anti-roll bar, but for the top mounting holes you need to fabricate an adapter plate and standoffs. I need to get one of these for my car so I can design and produce a batch of these adapter plates. I do not know, however, if there's enough space for the servo after this adapter plate is mounted up.
color0's MRCG1.1 color01 GSR 84 2010.02.15 03:48 AM
MRCG FAQ's (Important Update 12/21/08!) color01 GSR 9 2009.01.06 01:25 PM
Greyscale Racing MRCG Questions TheNotoriousROB Beginner Questions 3 2008.11.17 04:13 PM
MRCG Documentation (UPDATED) color01 GSR 0 2008.08.18 02:56 AM
The MRCG color01 GSR 1 2008.08.03 04:43 PM
