Old 2009.06.19, 12:28 PM   #1
Traveler
of both Time and Space
Traveler's Avatar
QteQ Mini-Z AWD Conversion set for FWD/RWD
CT-
The pics you posted of the QteQ MR-02 diff parts were very helpful to show what the diff will look like.
Can you do the same for the QteQ Mini-Z AWD Conversion set for FWD/RWD? I think I know how these would work but pics would be great! Assume the diff is removed, but how does this affect the center shaft movement front to back?
Thanks!
Old 2009.06.19, 12:40 PM   #2
CristianTabush
CristianTabush's Avatar
I have not installed them yet, but I am doing a rebuild of one of my cars, so I can do that in the process. Essentially, you keep the main shaft installed regularly, you never remove the pinion in the front, so movement is not an issue. Just remove the diff and replace the driveshafts with these axles and you are done...
Cristian Tabush
REFLEX RACING USA
http://www.reflexracing net
Old 2009.06.19, 01:18 PM   #3
Traveler
Traveler's Avatar
Thanks CT!
And the nut goes on the inside of these axles to keep them put?
Might be handy to have a set to use for adjusting the diffs. Put in front, get rear diff adjusted as needed. Put in back, get front diff adjusted. Remove axles and you have 2 perfectly adjusted diffs.
Old 2009.06.20, 09:59 PM   #4
MantisMMA
tire schredder
MantisMMA's Avatar
Good idea!
MantisWorx
www.rcshox.com
professional RC products
Marcus Williams
Tags
awd conversion, fwd, qteq, reflex, rwd
MA-010-MR-02 AD board set Conversion sciencemike Mini-Z AWD MA-010, MA-015 21 2009.08.16 02:09 PM
Wtb mini z awd ma-010 paul_england Mini-Z Marketplace 8 2008.10.23 03:59 PM
My I-Series MR-02 Conversion. Hammer i-Series 11 2007.12.31 04:51 PM
AWD conversion remo10 Mini-Z AWD MA-010, MA-015 4 2007.01.03 04:02 AM
miniz z awd conversion to overland bixu Mini-Z Overland MV-01 10 2006.04.17 09:33 AM
