Old 2009.07.12, 02:31 AM   #1
Mini-Z Lit
The same exciting performance and precision power, only smaller! Get hooked on the ultra-compact realism.
The MINI-Z sets itself apart from other R/C models by three principles: 1) Realistic running performance despite its small size; 2) Unmatched on scale detail, and 3) Sophisticated mechanical design that everyone can appreciate. The MINI-Z Lit is 100% faithful to these principles, just smaller in size. The minimal size of the MINI-Z Lit even makes the MINI-Z Racer and AWD seem large by comparison. But the MINI-Z Lit has compromised nothing in performance and build quality. In fact, its size makes replication of scale compact cars even more realistic and accurate. More than anything else, the fascination of the MINI-Z Lit must be how sophisticated R/C components have been loaded into such a compact design. And as with all MINI-Z models, the Lit comes fully factory assembled in a Readyset package including Ni-MH battery and diorama display / battery charger. You can even make setting changes by connecting the onboard I.C.S. to your PC (requires I.C.S. PC Interface sold by Kondo Kagaku and PC). Never has so much performance technology been concentrated in an R/C racing machine of this size! The MINI-Z Lit represents a new wave of micro motor sports.
Chassis Technical Data
Length 100mm (approx.)
Width 48~52mm
Height 26mm
Ground Clearance 3.5mm
Wheelbase 65~78mm
Tread (F/R) 42.5~46mm
Tire Size (F/R) 185.5mm
Gear Ratio 5.16, 4.43 : 1
Weight (approx.) 100g
Motor(incl.) SH030-Class
Features
Features newly developed looped antenna that sits inside the body shell. The open-top COPEN also comes with a rod antenna.
Chassis length is just 100mm. The same MINI-Z quality and immaculate scale form are obvious despite its smaller size.
King pin and coil system on the independent front suspension system produces zippy performance and excellent control.
Diorama display / quick charger unit operates at the push of a button with LED indicator (in the form of a street lamp) to show charging in progress.
Roll plate rear suspension system gives the chassis the racy performance to zip around the track.
Includes receiver and servo as well as 4.8V-150mAh Ni-MH battery to power the chassis.
Electronics Configuration
(No image) BET Band: Special FM radio system provides excellent signal stability and digital servo control. The unit is fitted with I.C.S. that uses graphical representation for precision servo and motor control amp settings through a computer.
Top picture property of Herman C., used on this page with permission.
Other images and text are property of Kyosho Corporation, and used on this page only for informational purposes.
color01 is offline
Closed Thread
Mini Cooper Monte Carlo LIT soulstice PN Racing 3 2007.06.05 09:27 PM
shop.tinyrc.com: Mini-Z LIT, Mini Inferno 09, Scary Coupon Deals! arch2b Mini-ZRacer.com Announcements 0 2006.10.22 07:50 PM
