Old 2009.07.16, 05:12 PM   #1
oopster
www.sldmodels.co.uk
Send a message via AIM to oopster Send a message via Yahoo to oopster
inteference
HI all, this might be a simple problem which I'll check on tomorrow. I've got some major radio glitching ony my F1, which might be low batteries, but if it is, it's only something that is affecting this particular F1.
Anyone any ideas what it might be? Worst case scenario is I get it sent off to get the electrics fixed which isn't a prob, but I should be running it this weekend.
oopster is offline   Reply With Quote
Old 2009.07.16, 10:22 PM   #2
rocketman
Thom Rocketman Belmont
rocketman's Avatar
What kind of radio do you use and do you use AM/AD or ASF?
Thom "The Rocketman" Belmont
Belmont Racing Team - BRT
rocketman is offline   Reply With Quote
Old 2009.07.17, 04:08 AM   #3
oopster
www.sldmodels.co.uk
using a ko ex10 helios with a 27mhz module. My 02 and AWD work fine with the same baterys.
Old 2009.07.17, 05:55 AM   #4
digger
is it just steering glitch or throttle aswell check the 2 wires that go from the crystal holder to the board they are prone to breaking had this on mine
digger is offline   Reply With Quote
Old 2009.07.17, 10:20 AM   #5
oopster
www.sldmodels.co.uk
Yeah, it's a bit of both. It's "better" when it's right next to my aerial, but i can't really run round the track following my car lol.
Will have a look at it again tomorrow when I'm in the shop and see if I can see anything.
Old 2009.07.17, 01:53 PM   #6
rocketman
rocketman's Avatar
Many things it could be, motors and brushes could be worn, loose wire, crystal problem but as it happens with this car and not the others that it is not in the radio but something quirky with a wire or something like that. Digger's suggestion is also right on the money as they are prone to have those problems?
Old 2009.07.18, 10:45 AM   #7
oopster
www.sldmodels.co.uk
It was the screw ixing the aerial in place making contact with something beneath. All sorted now.
Old 2009.07.18, 12:53 PM   #8
digger
glad you got it sorted its the little things that cause so much trouble got some new servo gears for mine
