Go Back   Mini-ZRacer.com Forums > Manufacturers > Reflex Racing
Old 2011.05.04, 08:59 AM   #136
JuniorWKR
White Knuckle Racing
JuniorWKR's Avatar
i centered the bearing...
Junior
Old 2011.05.04, 09:09 AM   #137
Traveler
of both Time and Space
Traveler's Avatar
Thanks JR! Do you know if you are using 2mm or 2.5mm bearing on your QteQ setups?
Old 2011.05.04, 12:03 PM   #138
JuniorWKR
JuniorWKR's Avatar
i will have to ask CT... it was whatever he sent me... i will find out and get back to ya...
Junior
Old 2011.05.04, 12:37 PM   #139
tr1kstanc3
I found a part number from Kyosho for 6x8mm shims.
KYO96046
tr1kstanc3 is offline   Reply With Quote
Old 2011.05.05, 05:26 AM   #140
Traveler
Traveler's Avatar
I just took a little closer look at mine and can better see what you did now.
Betting you used the 2mm thick center bearing, as its about the same thickness as the spur. I you had used the 2.5mm one, there would have been a gap between one or both of the AWD diff shims and the spur.
Went ahead and did mine like yours and hope it works better. Will have to let the CA set for a while... It was pretty stressful applying CA so close to the balls inside the bearing, but I think I kept the glue out because it still spins freely.
Thanks Junior!
Old 2011.05.05, 10:25 AM   #141
JuniorWKR
JuniorWKR's Avatar
no prob... let me know how you make out...
Junior
Old 2011.05.05, 10:59 AM   #142
JuniorWKR
JuniorWKR's Avatar
mine is with the 2.5mm bearing then. I have the space between the shim and the spur on both sides since i centered the bearing... once i had the shims in place and the glue was dry i then filled in the gap with a small amount of additional glue...
fwiw... i sanded the spur, bearing and shims to ensure the glue would maintian its bond... i ahve been running all three diffs this way for some time now and have rebuilt them multiple times and have not had a sigle shim come loose...
this application works wonders for me and keeps the shim centered perfectly...
i also did this on the reflex car that i built for kevin from action and he ran the car all day at the east coast districts and loved it..
Junior
Old 2011.05.05, 12:13 PM   #143
Traveler
Traveler's Avatar
Ooops! I used the 2mm bearing
Old 2011.05.05, 01:35 PM   #144
JuniorWKR
JuniorWKR's Avatar
try it... you may just have to add another washer shim if you find there is still to much play... it should work fine though...
Junior
Old 2011.05.05, 01:41 PM   #145
Traveler
Traveler's Avatar
We're racing tonight, so I will through it in a diff when I get to the track. Wondering if you encountered an issue with the AWD shims. The ones I have (don't know what brand) are not perfectly flat. I didn't sand them like you did, and I wasn't sure what orientation would be best, curved out like (spur) or curved in like )spur( . Think I ended up with (spur( . Any thoughts on this?
Old 2011.05.05, 02:44 PM   #146
JuniorWKR
JuniorWKR's Avatar
when i glued mine on i then sat them with the shim down on my pit board and then put a weight on top so when the glue dried it dried perfectly flat.. it worked perfect... then i just did the other side the same way..
Junior
Old 2011.05.05, 03:31 PM   #147
Kevin S.
Kevin S.'s Avatar
The car that Junior built for me for the East Coast Districts at MHS is absolutely sick. I absolutely love it. It is an all Reflex Car and I couldn't have been any happier with the way he built it for me Thanks Junior
Kevin S.
Action RC 2
Dream Killr Racing
Supporter of White Knuckle Racing
Kevin S. is offline   Reply With Quote
Old 2011.05.05, 09:12 PM   #148
JuniorWKR
JuniorWKR's Avatar
no prob homie... glad you like it... now you know why i like my cars so much... reflex makes great products for the racer in all of us...
Junior
Old 2011.05.08, 09:10 AM   #149
tr1kstanc3
I used a 2mm bearing centered equally inside the spur. I then glued one 6x8mm shim to the side that is closest to the right wheel. The left qteq hub was not sanded flat to the diff ring so it prevents the spur from rubbing that side. Everything stays centered now.
I used this shim set. http://www.amainhobbies.com/product_...etric-Shim-Set
Old 2011.05.08, 11:01 AM   #150
JuniorWKR
JuniorWKR's Avatar
aweswome.. thats great news... all my hubs where previously sanded so i used the 2.5mm bearings and the spacer on each side...
Junior
building a pan car jonnywachter Mini-Z Racer MR-02 49 2009.07.07 04:53 PM
Reflex Racing MR02 Setup Sheet ruf Setups 24 2005.04.07 09:07 PM
Reflex Racing exclusive F1 setup sheet! ruf Mini-Z F1 MF-010, MF-015 9 2005.04.06 10:19 AM
Spur gears mini-z racing Setups 1 2005.02.13 07:06 PM
PN Racing Delrin Spur Gear query revzalot Parts and Hop-ups 1 2005.01.09 01:53 PM
