Old 2009.08.01, 01:17 AM   #61
CristianTabush
CristianTabush's Avatar
I have not tried dying them. I would just mark them with a sharpie to tell them apart. The reason why I chose white delrin was to be able to identify wear easily and be able to replace them when necessary.
Cristian Tabush
REFLEX RACING USA
http://www.reflexracing net
Old 2009.08.01, 01:18 AM   #62
CristianTabush
Tim, good to know they worked out for you Funny you say they were snug on the PN Shaft. Was there perhaps a little bit of burring left in the center hole?
Thanks for the feed back I really appreciate it guys...
Cristian Tabush
REFLEX RACING USA
Old 2009.08.01, 05:16 AM   #63
pedrocamp
Ain'tSoldEm
I ordered two and one of them was tight on the PN shaft, nothing a deburr-scraper tool won't take care of though. My car felt faster out of the corner and diff action was improved, thanks Reflex...
Old 2009.08.01, 07:00 AM   #64
dvsstrike
The name is Tim
dvsstrike's Avatar
no burr in the hole. just snug. i just ran a reamer through it
Team Associated
Old 2009.08.01, 09:29 AM   #65
MantisMMA
tire schredder
MantisMMA's Avatar
interesting, about the snug fit although its better to be tight than loose in this situation but we did not come across that in testing. has anybody tried the RR spur with a complete qtec setup along with either the PN al shaft or 3r ti shaft yet? i would like to have some feedback from a PN70 car.
MantisWorx
www.rcshox.com
professional RC products
Marcus Williams
Old 2009.08.01, 09:30 AM   #66
MantisMMA
tire schredder
MantisMMA's Avatar
to answere your question Tom, the dye will not effect the delrin. this brings up a point though. i think i can get grey black and white delrin.
MantisWorx
www.rcshox.com
Marcus Williams
Old 2009.08.01, 09:39 AM   #67
CristianTabush
Check the OD on your PN Shafts... Make sure they are the same. These were all cut on a NASA- precision CNC Machines. I will start checking the spurs for these inconsistencies as well. Glad you all like them so far...
Cristian Tabush
REFLEX RACING USA
Old 2009.08.01, 12:06 PM   #68
MantisMMA
tire schredder
MantisMMA's Avatar
the same drill was used for all of the parts and they were drilled at the same time so the hole sizes are all the same. so either there is a burr on the hole or the PN shaft may be on the high side of their tolerance.the drill cannot make a smaller hole its impossible but it can make a bigger hole.
MantisWorx
www.rcshox.com
Marcus Williams
Old 2009.08.01, 01:38 PM   #69
I am going to be building a Qteq/3Racing ti/Kyosho plate diff with Reflex balls and spurs... just need to find my shaft, I misplaced it
Old 2009.08.01, 03:47 PM   #70
dvsstrike
The name is Tim
dvsstrike's Avatar
Talking
i hate when i misplace my shaft! but the topic at hand...i'm running all qtec an the pn alum sfat as well as nitride diff balls, works awsome with the pn70t.
Team Associated
Old 2009.08.01, 04:08 PM   #71
CristianTabush
Just got done measuring a fairly large sample of each. The Spurs vary within 0.1mm in ID, the Shafts vary within 0.1mm in OD. If you happen to get a big shaft and a small spur, this is a 0.2mm variation, which would account for them being a little tight. So neither product seems to be flawed. I much rather have tight than loose fit though.
Cristian Tabush
REFLEX RACING USA
Old 2009.08.01, 05:08 PM   #72
MantisMMA
tire schredder
MantisMMA's Avatar
so going from your normal diff to the "super" diff what driving characteristics did you notice? were you able to run faster times?
MantisWorx
www.rcshox.com
Marcus Williams
Old 2009.08.01, 08:33 PM   #73
pedrocamp
Ain'tSoldEm
I am running the full QTEQ kit with the PN aly shaft. I tried both spurs on this same shaft and found one snug and one that fit nicely. I agree it is just tolerance overlap, I'd rather have them slightly snug and finish to fit than loose. I found that I didn't have to crank down on the diff as much and the car accelerated better. My diff has a bit more noise than I did with the PN 53T. I changed pinions and still had the gear noise, a little quieter though. I will have to fit up my other spur gear and see how noisy that one is. Both my pinions are used, the second one has very few laps though. I will try a new pinion as well.
Old 2009.08.02, 01:21 AM   #74
bobbyz
just wanting to check if these new spurs will fit on a Kyosho MR-01 diff shaft also?
thanks, bob
bobbyz is online now   Reply With Quote
Old 2009.08.02, 04:55 AM   #75
CristianTabush
They are going to make a little more noise than the plastic ones if not meshed correctly because the material is much harder, this is just a property of harder materials.
As for fitting the MR01 diff, It should, I can't think of why it would not work.
Cristian Tabush
REFLEX RACING USA
building a pan car jonnywachter Mini-Z Racer MR-02 49 2009.07.07 05:53 PM
Reflex Racing MR02 Setup Sheet ruf Setups 24 2005.04.07 10:07 PM
Reflex Racing exclusive F1 setup sheet! ruf Mini-Z F1 MF-010, MF-015 9 2005.04.06 11:19 AM
Spur gears mini-z racing Setups 1 2005.02.13 08:06 PM
PN Racing Delrin Spur Gear query revzalot Parts and Hop-ups 1 2005.01.09 02:53 PM
