Old 2009.11.13, 07:16 PM   #16
Dr. Kustom
Dr. Kustom's Avatar
Send a message via MSN to Dr. Kustom
Thanks man!
Update: Build a few different types of fog lights, let me know which one ya like the best.
Type 1:
Type 2:
Type 3:
I personal think type 3 looks the best for this project.
And here a little something I have been working on... can't show much since I'm only working on 1 wheel arch.
GSR / Atomic
Dr. Kustom is offline   Reply With Quote
Old 2009.11.13, 10:53 PM   #17
Dr. Kustom
Dr. Kustom's Avatar
Update: I made up my mind and went with the type 2 fog lights. I also added more details on the lense and clear coat it.
Then I sand down the case to get rid of those part tree tabs, and drilled a hole for LED. ( I will be re-painting the case silver. )
And here's a little teaser.
GSR / Atomic
Old 2009.11.14, 02:09 PM   #18
Dr. Kustom
Dr. Kustom's Avatar
Today was raining, so i deiced to take the truck outside for a run.
Here's a short video to prove that it can handle some water.
GSR / Atomic
Old 2009.11.14, 03:48 PM   #19
jeremym
jeremym's Avatar
Thats awesome! Very nicely done.
jeremym is offline   Reply With Quote
Old 2009.11.17, 03:47 PM   #20
Dr. Kustom
Dr. Kustom's Avatar
Update: Something I have thought of that might add traction when running on snow.
GSR / Atomic
Old 2009.11.20, 10:13 PM   #21
Dr. Kustom
Dr. Kustom's Avatar
About time for another short video. Front & rear differentials are still un-locked.
GSR / Atomic
Old 2009.11.23, 02:29 PM   #22
Dr. Kustom
Dr. Kustom's Avatar
Update: Got a few more GPM parts and a set of new tires.
I'll need to re-do those wheel flares and make the wheel arch bigger, then I can run those tires.
GSR / Atomic
Old 2009.12.02, 10:11 PM   #23
Dr. Kustom
Dr. Kustom's Avatar
Update: More GPM...
GSR / Atomic
Old 2009.12.02, 10:12 PM   #24
Dr. Kustom
Dr. Kustom's Avatar
Snorkel. (W.I.P)
Its not finished yet.
GSR / Atomic
Old 2009.12.03, 04:00 PM   #25
Mania
That is one mean looking truck you have there.
Mania is offline   Reply With Quote
Old 2009.12.07, 08:16 PM   #26
Dr. Kustom
Dr. Kustom's Avatar
Thanks Mania!
Update: Finished the snorkel.
Start the roof rack and trailer hitch.
The roof rack start off from a model kit part tree.
GSR / Atomic
Old 2009.12.08, 06:29 AM   #27
monkey19
monkey19's Avatar
Send a message via Yahoo to monkey19
looks great!
Joe
"remember you are a genius until you open your mouth"- Stuart Wilde
monkey19 is offline   Reply With Quote
Old 2009.12.08, 02:26 PM   #28
Dr. Kustom
Dr. Kustom's Avatar
Thanks man!
Update: Got new rims. o.o Thank you xmodcanuck for making the rims.
GSR / Atomic
Old 2009.12.09, 11:09 PM   #29
Dr. Kustom
Dr. Kustom's Avatar
Update: The 2.4GHz PCB just shipped out to XXX today for a 2x3 Stacked FET, also ordered a Stock R motor. Since I'm using the new rims now, I got a wider off-set, +3 wide all around, with that much off-set and those huge bogger tires, I need to sand down more plastic on the wheel well and the wheel flare. The front wheel flares on the body are now 47mm wide, and 45mm for the rear.
And the starting of the interior...
Mock up.
Did some work to the driver seat. Since the passenger seat sit higher on the chassis, because it located right above the PCB, so I need to raise the driver seat up a little bit too.
Sanding down the mold lines.
GSR / Atomic
Old 2009.12.09, 11:10 PM   #30
Dr. Kustom
Dr. Kustom's Avatar
Arm rest.
The arm rest that comes with the model kit are nice, but they aren't really detailed, so I add styrene to cover up the back side of the arm rest. (left is original and right is detailed.)
And finally come to mounted the driver seat.
That's it for now, more update to come later.
GSR / Atomic
Losi 1/36 Micro-Desert Truck arch2b Mini RC 57 2008.04.05 09:30 PM
weight distribution question james399 Mini-Z Overland MV-01 21 2005.11.28 02:54 AM
New MOnstro Truck NYCMINIZMONSTER Mini-Z Monster MM-01 6 2004.09.18 10:37 PM
OL MONSTER GARAGE PROJECT: Dodge Hemi Race Truck DogbreathRacing Mini-Z Overland MV-01 48 2004.06.25 07:03 AM
