Old 2009.12.05, 11:10 AM   #1
MXMRCR
MXMRCR's Avatar
atomic knuckle problem
i just got these atm knuckles and the atm bearings don't even fit over the axle, i have these same knuckles on my MM and they are fine, anyone had this problem or got any solutions...
thanks for looking
NoWayPedro
#BTRR
MXMRCR is offline   Reply With Quote
Old 2009.12.05, 11:52 AM   #2
MXMRCR
MXMRCR's Avatar
i just got these atm knucles and the atm bearings don't even fit over the axle, i have these same knuckles on my MM and they are fine, anyone had this problem or got any solutions...
thanks for looking
NoWayPedro
#BTRR
Old 2009.12.05, 12:06 PM   #3
mk2kompressor
at the Bleeding Edge
mk2kompressor's Avatar
yup had the same problem in the past with the older v2 knuckles,had to sand the shaft a little
Team B.E.R.T
MR02/3 eating MA010
MR-03
HFAY S9 F1 Winner
Sinister V1
MRCG Prototype
MRCG 1.0
Bleeding Edge Racing UK
Old 2009.12.05, 12:07 PM   #4
MXMRCR
MXMRCR's Avatar
thanks matt, i'll give it a shot but i don't wanna damage the thread.
NoWayPedro
#BTRR
Old 2009.12.05, 12:10 PM   #5
mk2kompressor
you shouldnt damage the thread,use 500g wet and dry.
the shaft will just need a tickle
Team B.E.R.T
MR02/3 eating MA010
MR-03
HFAY S9 F1 Winner
Sinister V1
MRCG Prototype
MRCG 1.0
Old 2009.12.05, 12:19 PM   #6
MXMRCR
MXMRCR's Avatar
okay cool, i'll do it tomorrow and let you if i get them rolling,
thanks again matt.
NoWayPedro
#BTRR
Old 2009.12.05, 01:53 PM   #7
1. please post to an appropriate area. kyosho is not the best place for a discussion on atomic knuckle issues.
2. DO NOT POST THE SAME TOPIC MULTIPLE TIMES.
every brand lets a few bum units out. i've had pn parts that had milling flaws, angled taped holes or holes not tapped. atomic and pn have been more consistent for me than 3racing and gpm.
yes, i've had the same issue with pn knuckles even. it's either shaft tolerances or bearing tolerance issue. i just changed out the bearing and moved on. odd thing is, it's only happened with a couple bearings. maybe 4 out of 12.
you could try polishing the shaft to remove the smallest fraction of material or contact the retailer and or manufacturer for a replacement or refund. no point in keeping a bum part.
Old 2009.12.06, 11:46 AM   #8
MXMRCR
MXMRCR's Avatar
sorry for posting in wrong section,
anyway the wet'n'dry worked perfectly and i did take some 'autosol' polish to bring the shine back (thanks arch2b), problem solved...thanks guys.
NoWayPedro
#BTRR
anyone wanna buy my MA-010 AWD? pinoyboy Atlanta Mini Scale Racing 19 2007.04.24 01:39 PM
Problem: Atomic DPS II for RM RMDave Mini-Z Racer MR-02 2 2007.03.24 08:31 AM
Spur gear skiping Atomic diff in SAS WeBoC Mini-Z AWD MA-010, MA-015 13 2007.03.06 03:21 PM
Atomic AWD S. Knuckle II Ton Mini-Z AWD MA-010, MA-015 6 2006.12.21 12:08 AM
