Go Back   Mini-ZRacer.com Forums > Manufacturers > Reflex Racing
Old 2009.12.22, 08:21 PM   #16
CristianTabush
CristianTabush's Avatar
What's expensive is not actually doing the threads, but adding the hex head. We had thought about making a slot for this reason, but this means that each kingpin has to go through an extra operation, vs just being made on a lathe.
Cristian Tabush
REFLEX RACING USA
http://www.reflexracing net
Old 2009.12.22, 08:45 PM   #17
yasuji
PN RacingTEAM Driver
yasuji's Avatar
Originally Posted by CristianTabush View Post
This is exactly what we considered doing when working out the design with Marcus, but space is at a premium and cost goes up 3-fold.
Another thing is up-stoke can be limited with different height spring cups, where with a nut, you would have to use spacers on the king-pin to do so (or different size nuts, which also increases cost). I figure, this ends up being as much work as just adding shims to increase pre-load. :P
fair enough.... how about an adjustable clip position...jus like a jet needle on a motorcycle carb.....and using the same clips from the diff?
Grant "Yasuji" Matsushima
www.pnracing.com
gm@pnracing.com
Old 2009.12.22, 08:56 PM   #18
CristianTabush
That's not a bad idea. But one thing I like about plastic clips is that they are SOOOOO easy to remove. The diff clips can be a pain in the butt. They would save space, but would make changes much harder. Isn't using shims easier?
Cristian Tabush
REFLEX RACING USA
Old 2009.12.22, 11:10 PM   #19
hobbycar
hobbycar's Avatar
Love the simple design.
I also like the plastic clips so much better than metal e-clips (like on the diff). Half the time I take off metal e-clips I end up bending them, losing them (as they shoot across the room), or drawing blood on my finger .
I agree plastic clips are the way to go as long as they are secure and have no chance of coming off in a race or high speed crash.
-hobbycar
hobbycar is offline   Reply With Quote
Old 2009.12.23, 03:36 AM   #20
Rune
Mini-Z Norway
Rune's Avatar
Wow! That was a smart invention.
Cant wait to try it out.
No more flexing arms, springs that can pop out in a crash, and so easy to change setup.
What about a WTF3?
Mini-Z Norway
Old 2009.12.23, 03:55 AM   #21
cool design... and much cooler to use 02 stuff as well...
Old 2009.12.23, 07:46 AM   #22
hpgod
Now cut the extra spring arm off the upper a arm and get even better bump performance by reducing the unsprung weight.
Great idea CT
Cannot wait to try in on the my 03 under the christmas tree
Old 2009.12.23, 09:24 AM   #23
i too like the simplicity used. it's a bonus that most parts are off the shelf
i look forward to trying this.
Old 2009.12.23, 09:47 AM   #24
Cherub1m
Slip Angle Chaser
Cherub1m's Avatar
Thanks Guys! Yeah, with the spring being on top, there is no need for heavier duty a-arm to prevent flexing. Plus, it will be VERY economical. Kingpins and delrin balls should be around 10-15 bucks TOPS!
Very nice!. Simple, economical, and not much added weight and it looks like it will be effective. Great work!!!
Philip Vincent
Old 2009.12.23, 10:51 AM   #25
HaCo
02-Racer
HaCo's Avatar
Great work from reflex!
SRL in Belgium with permanent Mini-Z track!!!
Mini-Z News!!!
Handy RCP track editor!
Old 2009.12.23, 11:12 AM   #26
Good work CT and Marcus -- I'd been trying to get a hold of some spare 03 pivot balls so I could stick 02 kingpins through them (essentially the same mod as you've done there), but now you've gone ahead and made the necessary bespoke part itself. Very nice. I just hope they are not gold-plated, but titanium-nitride coated. Gold plating isn't the right thing to do here for several reasons.
Old 2009.12.23, 01:49 PM   #27
mr7q
That is brilliantly simple! Or simply brilliant! I love it when engineering and efficiency match themselves up.
I'm a fan and will be putting it on my MR-03.
Why does everybody keep waving that blue flag at me...
mr7q is offline   Reply With Quote
Old 2009.12.23, 08:04 PM   #28
Tjay
Tjay's Avatar
Oh YES!!! Definitely better! I will order this for sure... hopefully before Tekin.
Old 2009.12.24, 02:59 AM   #29
SaiTam
Are you Fetted?
SaiTam's Avatar
Amazing! I'm glad this is not a Front suspension kit with a $80 price tag and eight moving parts. I can afford five sets. One for myself; three for my enemies; the last one can be used for raffle.
Old 2009.12.24, 03:03 AM   #30
CristianTabush
Thanks Sai!
Cristian Tabush
REFLEX RACING USA
Reflex Racing Endurance Series - October 10, 2009 CristianTabush Events 151 2009.11.02 09:51 AM
building a pan car jonnywachter Mini-Z Racer MR-02 49 2009.07.07 05:53 PM
Reflex Racing arch2b Reflex Racing 0 2009.06.09 08:11 PM
Can I lower the front end of my Z? smify_101 Custom Bodies 12 2003.07.09 03:18 PM
my rookie review: front end springs West.F1 Mini-Z F1 MF-010, MF-015 12 2002.07.01 12:08 AM
