Old 2010.01.05, 10:46 AM   #1
PNracing
Send a message via AIM to PNracing Send a message via Yahoo to PNracing Send a message via Skype™ to PNracing
MR03 Aluminum Low DOwn Knuckle
Pre load down 0.7mm
Aluminum knuckle
Stainless Steel Pin
Delrin Insert
Gas hole to put King Pin Oil
http://www.pnracing.com
http://PNWC.pnracing com
DownloadPNICS ICS Android Apps for ICS Setting
PNracing is offline   Reply With Quote
Old 2010.01.05, 12:45 PM   #2
i noticed these on your site this weekend
are there comparison images of this product next to the stock knuckle?
Old 2010.01.05, 12:55 PM   #3
chad508
chad508's Avatar
are we going to be able to get these in any camber other than 0?
Old 2010.01.05, 01:00 PM   #4
PNracing
If make the camber at the knuckle is not good, big camber on the wheel pin, it will be make the wheel hit the upper arm, and the camber gain change to fast.
Upcoming we had camber Upper Arm with adjustable caster release.
Old 2010.01.05, 02:07 PM   #5
chad508
chad508's Avatar
my bad. i now recall that you were coming out with adjustable upper arms. thanks
Old 2010.01.05, 02:07 PM   #6
JuniorWKR
White Knuckle Racing
JuniorWKR's Avatar
the knuckle being a low down is going to create camber on its own as it will sit higher up the kingpin...
Junior
Old 2010.01.05, 05:04 PM   #7
Rune
Mini-Z Norway
Rune's Avatar
Cool. These look really nice.
Mini-Z Norway
Old 2010.01.05, 05:20 PM   #8
Junior, I dont know if the knuckle sits higher on the kingpin, I think the axle is higher on the knuckle??? I think preload on the spring, and position of the upper arm will be the same as it is with stock.
^ is just speculation, I have no inside source for this...
Old 2010.01.05, 10:13 PM   #9
lfisminiz
lfisminiz's Avatar
Look great and gain more strength.
Old 2010.01.06, 12:59 AM   #10
I've been using these for a while, there's no camber gain but the ride height drop is perfect. This one's a must-have.
Old 2010.01.06, 08:12 AM   #11
JuniorWKR
JuniorWKR's Avatar
if the knuckle/axle sits higher on the kingpin it will generate more camber quicker as it takes less travel to get to the top... by raising the knuckles on my 03's it lifts the upper arm which is what causes camber...
Junior
Old 2010.01.06, 11:54 AM   #12
pedrocamp
Ain'tSoldEm
Camber gain is dependent on the angle of the upper arm. Raising the axle on the knuckle doesn't change the upper arm angle, only lowers the chassis relative to the axles. You could change camber gain by shimming on top of the knuckle but you need correspondingly shorter springs (or remove shims underneath it if available) to get the ride height back.
Post images of your Monster carfreak_22 Mini-Z Monster MM-01 28 2012.10.23 02:13 PM
WTB : Monsters TamiyaBF Mini-Z Marketplace 11 2009.02.24 11:51 AM
aluminum steering knuckle question youpey Mini-Z AWD MA-010, MA-015 10 2006.09.19 02:00 PM
Kyosho aluminum rims ~VS.~ Square aluminum rims G'ZOX Mini-Z Racer MR-02 7 2005.08.15 09:31 PM
