Go Back   Mini-ZRacer.com Forums > Manufacturers > MantisWorx
Old 2010.01.18, 06:56 PM   #31
B-main
previously spakey
B-main's Avatar
kick a$$ wheels mantis .cant wait to get a few sets.
mbmzr
let's go racing
B-main is offline   Reply With Quote
Old 2010.01.18, 08:57 PM   #32
MantisMMA
tire schredder
MantisMMA's Avatar
thanx man! hope to keep makin cool stuff for everyone. i got some good ideas comin!!
MantisWorx
www.rcshox.com
professional RC products
Marcus Williams
Old 2010.01.22, 11:49 AM   #33
CristianTabush
CristianTabush's Avatar
Pictures and Pre-orders Going up tonight! Get them while they are hot off the CNC Machine!
I already have some sold, so I am sure they won't last long...
Cristian Tabush
REFLEX RACING USA
http://www.reflexracing net
Old 2010.01.22, 12:26 PM   #34
yasuji
PN RacingTEAM Driver
yasuji's Avatar
will you be making the fronts in a std size? 20 mm....if so could you use the rear hub to make it a + 3 offset front?
Grant "Yasuji" Matsushima
www.pnracing.com
gm@pnracing.com
Old 2010.01.22, 02:10 PM   #35
MantisMMA
tire schredder
MantisMMA's Avatar
i have a few sets of std fronts that i can sell to you. the hubs are different sizes and the grooves are spaced differently from front to rear. a +3 in the front is going to cause alignment problems with the grooves and durability. next run i can make a +2 (i think). once i get through the first few initial runs i will have many options. you will be able to purchase lips alone or hubs alone, different colors (grey and white) and i have some other wheel pattern designs that look good too! this is going to be an on going deal and i may even offer one pc wheels too down the road!
MantisWorx
www.rcshox.com
Marcus Williams
Old 2010.01.22, 03:15 PM   #36
Traveler
of both Time and Space
Traveler's Avatar
I've put my order in.
Nuf said
Old 2010.01.23, 12:27 PM   #37
CristianTabush
Pre-orders are up. Product No. is MW001 just use the search bar.
Cristian Tabush
REFLEX RACING USA
Old 2010.01.23, 01:16 PM   #38
MantisMMA
tire schredder
MantisMMA's Avatar
they are on the machine right now, should have them all ready in a few hours. only have 18sets for the first run. more to come in a couple of weeks!
MantisWorx
www.rcshox.com
Marcus Williams
Old 2010.01.23, 01:51 PM   #39
LED
do you have a picture of the second part? the hub ?
Old 2010.01.23, 02:09 PM   #40
CristianTabush
Not at the time...
Cristian Tabush
REFLEX RACING USA
Old 2010.01.23, 05:21 PM   #41
Rune
Mini-Z Norway
Rune's Avatar
Ordered. Looks great.
Will they be available without the tool in the future?
Mini-Z Norway
Old 2010.01.23, 06:08 PM   #42
MantisMMA
tire schredder
MantisMMA's Avatar
the middle is the second part/hub.
Rune, the wheels wiil be sold without the tool in the future but if you do not have the tool you will damage the wheel when you try to adjust offsets.
for those that ordered the wheels already and for those that plan on purchasing them it is VERY important that you glue the rear wheels from the inside once you have found your prefered offset, the front not so much but if you get hit hard in the rear without glue the wheel will move. and it is also important that you only try to adjust the wheels in the same direction , dont go fwd and then try and go the opposite way. the face of the hub goes on top of the tool and you press the lip down on to the hub. if you pass up ur offset just go all the way through and start over.
what do you guys think about this design:
i made two sets this way today just to see what it would look like!
MantisWorx
www.rcshox.com
Marcus Williams
Old 2010.01.23, 07:00 PM   #43
hcw0zone
hcw0zone's Avatar
Thumbs up
Great !!!! will you be making the fronts of 17mm LM ???
hcw0zone is offline   Reply With Quote
Old 2010.01.23, 08:00 PM   #44
MantisMMA
tire schredder
MantisMMA's Avatar
probably not but the front rims are 19mm in dia and when you use normal tires they are the same diameter as LM rims with LM tires but you get a better selection of front tires. i will post a pic late tonight of a LM body with the wheels on it.
MantisWorx
www.rcshox.com
Marcus Williams
Old 2010.01.23, 09:37 PM   #45
Rune
Mini-Z Norway
Rune's Avatar
Thanks. I was thinking when you need replacement wheels etc. No need for more than one tool.
Mini-Z Norway
The Official Nor Cal Racing Thread Rick Tracks and GTGs 14 2006.08.24 01:47 AM
Hot Wheels Kit Racing part4a Mini RC 2 2002.08.24 01:02 PM
Anyone use RC Racing Model wheels? Zero_effect Parts and Hop-ups 5 2002.06.04 05:35 PM
