Old 2010.01.22, 12:25 PM   #1
pinwc4
pinwc4's Avatar
Compatible RFID tags
Since there has been various discussions about what RFID tags will work with what lap counting hardware I thought it would be good to get it focused into one thread.
The TI ISO15693 RFID tags are identical to the Core branded tags except they are not covered by paper. For these generic tags you need to protect the exposed side with tape or a paper label.
For those of you that have experimented with this can you please provide the following info for things that have or have not worked:
  • RFID Manufacturer model number (or dNaNo of it is the integrated tag)
  • RFID Dimensions
  • Lap counter type, Kyosho IC, Core with clear solid wire or Core with black coax wire
  • Car types tried on, MR-02, F1, dNaNo etc.
  • Did the tag work or not?
  • If it worked a link to where to buy it and the price
  • Any special notes about use of the tag, such as must be mounted in front etc.
I will update this post with the compiled information.
Core lap counter with black coax antenna
Tags known to work
Core lap counter with clear solid wire antenna
Tags known to work
Tags reported to not work
  • dNaNo
Kyosho IC lap counter
Tags known to work
  • dNaNo
Flip Side Racing Software Info pinwc4 Flip Side 0 2009.05.01 10:29 PM
Where can I get Core Transponders? Z_408 Core Lap Timing System Support Forum 38 2007.04.04 07:49 AM
FS FT: MA010 - MR01 - MR01.5 Compatible Narrow Bodies & Monster Body Draconious Miscellaneous Discussion 23 2006.09.28 05:12 PM
compatible parts marc12 Mini-Z Monster MM-01 0 2004.01.10 09:57 PM
