Old 2010.04.06, 10:38 PM   #1
MantisMMA
tire schredder
MantisMMA's Avatar
MantisWorx F1 tower bars
these are available in
2*camber/3*caster
price is 12.00pr
installation:
if you want to retain the use of the stock springs.
tools needed:
cordless drill/dremel
.140-.155 drill ( allows kingpin to "lay over")
cartridge roll ( to grind off the top of the shock towers)
1. completely dis-assemble the fornt end
2. SLOWLY drill (.140-.155 drill)only the top of the shock tower, if you push too much you can/will break it completely off.
3. using the cartridge roll grind off the top of the shock tower approximately 1.5mm. if you go too far dont worry about it, the tension in the arms will keep the kingpin at the top. the only reason the tower is there is for the spring stop.
4. re-assemble in reverse order but the "C" clip goes on top of the new tower bar and the bar screws down in the factory location!
ADVANCED users:
i have discovered that if you completely remove the factory tower bars and only use the MantisWorx bars you can use the PN MR03 lowdown springs and have a better selection of springs. only thing required is a thin flat washer on top of the knuckle between the spring and thats it.
MantisWorx
www.rcshox.com
professional RC products
Marcus Williams
Old 2010.04.06, 10:40 PM   #2
MantisMMA
tire schredder
MantisMMA's Avatar
those who pre-ordered will be shipped tomorrow. please use this thread for discusion on setups and feedback. if i need to change something just let me know or if a different combo is desired as long as you prepay a few sets i can make whatever you want!
MantisWorx
www.rcshox.com
Marcus Williams
Old 2010.05.03, 10:33 PM   #3
MantisMMA
tire schredder
MantisMMA's Avatar
new design!
http://shop.mantisworx.com/TOWER-BAR-MWX-TB001-V1.htm
MantisWorx
www.rcshox.com
Marcus Williams
Old 2010.05.25, 03:33 PM   #4
tudor_47
tudor_47's Avatar
Originally Posted by MantisMMA View Post
ADVANCED users:
Marcus,
could you be more specific on this modification? I assume that it is only the top portion of the factory tower bar that you remove?
Can normal length PN-springs be used without the washer?
Is there a drawing of how it is done, I think I got it but, I wanna be sure before cutting into the main chassie part of my F1......
And if you do this is a suspension limiter a good thing?? or is stopping against the Mantisworx top arms enough?
Thanks!
/Johnny
Get a P28
Old 2010.05.25, 10:19 PM   #5
MantisMMA
tire schredder
MantisMMA's Avatar
it depends on what knuckles you have you can use either the full length 03 springs or 02 springs. good thing is that you can shim to adjust droop. and you only need to remove the top portion of the tower but i have also discovered that some knuckles will actually rub against the side of the tower and slightly bind up so i completely ground mine all the way off. i will put some pix up on the site tomorrow.
MantisWorx
www.rcshox.com
Marcus Williams
Old 2010.05.26, 01:24 AM   #6
tudor_47
tudor_47's Avatar
Thanks!
Will be keeping my eyes on your site...
/Johnny
Get a P28
Old 2010.06.04, 02:49 PM   #7
tudor_47
tudor_47's Avatar
Any luck in the pictures?
Thanks!
/Johnny
/Johnny
Get a P28
Old 2010.06.04, 03:06 PM   #8
MantisMMA
tire schredder
MantisMMA's Avatar
Not yet I am super swamped! But if you look at the readers rides or any pix of my R30 you can see how it is done in the meantime. I am setting aside Sunday to get it done.
MantisWorx
www.rcshox.com
Marcus Williams
Old 2010.06.04, 05:01 PM   #9
tudor_47
tudor_47's Avatar
Ok,
Shall I grind the "shoulder" under the rearmost screw down so that it is level with the chassis?
edit:
another thing... the drillbits can you translate them to metric sizes?
i get 3,5mm for .140 and i am getting worried is that not to big??
Edit2
I have now tested using 3mm drill and it looks OK with 2,5-4mm drillbit..
/Johnny
Get a P28
Old 2010.06.04, 05:13 PM   #10
MantisMMA
tire schredder
MantisMMA's Avatar
dont grind anyting off of the main chassis, the only thing you have to grind is the top of the stock towers. 3.5mm for the drill.
MantisWorx
www.rcshox.com
Marcus Williams
Old 2010.06.04, 05:16 PM   #11
MantisMMA
tire schredder
MantisMMA's Avatar
be very carefull drilling the hole it will grab if your not carefull but if it does happen just grind the whole thing off and use MR03 springs.
MantisWorx
www.rcshox.com
Marcus Williams
Old 2010.06.04, 05:20 PM   #12
MantisMMA
tire schredder
MantisMMA's Avatar
gimme about ten minutes and i wil post a sketch, your scaring me!
MantisWorx
www.rcshox.com
Marcus Williams
Old 2010.06.04, 05:26 PM   #13
tudor_47
tudor_47's Avatar
Thanks!
the shoulder is the one that can be seen in this picture...
/Johnny
Get a P28
Old 2010.06.04, 05:39 PM   #14
MantisMMA
tire schredder
MantisMMA's Avatar
this is all you have to grind
MantisWorx
www.rcshox.com
Marcus Williams
Old 2010.06.04, 05:41 PM   #15
MantisMMA
tire schredder
MantisMMA's Avatar
Originally Posted by tudor_47 View Post
Thanks!
the shoulder is the one that ccan be seen in this picture...
you dont touch anything on the black part, only on the clear
MantisWorx
www.rcshox.com
Marcus Williams
PN Front Caster Tower Bar Version 2 benmlee PN Racing 1 2008.09.28 02:53 AM
Why not to buy from tower, especialy when they seem to hate you as much as they do me Draconious Miscellaneous Discussion 13 2004.12.31 02:17 PM
hummer bed bars racemini89 Mini-Z Overland MV-01 1 2004.04.24 12:10 PM
FOR SALE: Partialy New? used? Refirbished? Tower mess up Mini-Z Readyset Draconious Miscellaneous Discussion 4 2002.11.06 09:18 PM
