Old 2010.06.04, 06:50 PM   #16
tudor_47
tudor_47's Avatar
OK
nothing done to black part of chassie...
the clear chassie top part is down to approx...2mm thickness now...
this givves that the new upper carbon arm is floating in the air above the clear arm.....
I will continue to assembly som other night... it is almost 1 in the mornig now..
THANKS!
THANKS!
/Johnny
Get a P28
Old 2010.06.04, 07:11 PM   #17
MantisMMA
tire schredder
MantisMMA's Avatar
thats ok, all the tower bar does is locate the kingpin and once you clip the C clip on it will be snug enough.
MantisWorx
www.rcshox.com
professional RC products
Marcus Williams
Old 2010.09.14, 04:15 AM   #18
tudor_47
tudor_47's Avatar
Originally Posted by MantisMMA View Post
ADVANCED users:
i have discovered that if you completely remove the factory tower bars and only use the MantisWorx bars you can use the PN MR03 lowdown springs and have a better selection of springs. only thing required is a thin flat washer on top of the knuckle between the spring and thats it.
I did this and I used the shortest aluminium downstop for an mr02 that I had in the box and put that closest to the knuckle and it did the trick and it added downstop to the front suspension. I took a picture of the installed knuckle with the red alu downstop and a PN short Mr02 spring.
/Johnny
Get a P28
Old 2010.09.14, 09:32 PM   #19
MantisMMA
tire schredder
MantisMMA's Avatar
nice! if you notice, you also get some Tower bar flex too which helps out.
MantisWorx
www.rcshox.com
Marcus Williams
PN Front Caster Tower Bar Version 2 benmlee PN Racing 1 2008.09.28 03:53 AM
Why not to buy from tower, especialy when they seem to hate you as much as they do me Draconious Miscellaneous Discussion 13 2004.12.31 03:17 PM
hummer bed bars racemini89 Mini-Z Overland MV-01 1 2004.04.24 01:10 PM
FOR SALE: Partialy New? used? Refirbished? Tower mess up Mini-Z Readyset Draconious Miscellaneous Discussion 4 2002.11.06 10:18 PM
