Old 2010.07.13, 09:22 PM   #16
machgo5go
DJ Eddie!
machgo5go's Avatar
Question on the proper spacers that came with the T-Plate.
OEM Kyosho plastic on have one end shave down in less thickness in order to be flush under the F1's battery tray.
The Carbon 2 pieces is all equal thickness so when I install it, T-plate never be flush along the Batteries Tray's bottom.
Am I missing something in the idea of these 2 spacers?
MR-03 Mclaren MP-12CGT3 AT70T
MR-03 S2K Narrow AT60T Nihm
MR-03 BRZ Narrow PN70T Nihm
AMZ Benz TC 8500KV
X Power IDT Ultra 5600KV Audi
X Power IMT Ultra 6800KV M3
214 State St. Suite 209
DG DESIGNS
machgo5go is offline   Reply With Quote
Old 2010.07.13, 09:30 PM   #17
MantisMMA
tire schredder
MantisMMA's Avatar
Not sure if I understand your question but you no longer use the battery tray, the t plate takes it place you can either use the kyosho spacers or the mantisworx spacers but not both. The MW spacers are desugned to be used with the MW barge board. You can trim off the OEM barge board if you use the MW spacers, they are thinner than the kyosho spacers therefore eliminating the spacer that is normally used on the motor mount.
MantisWorx
www.rcshox.com
professional RC products
Marcus Williams
Old 2010.07.13, 10:03 PM   #18
machgo5go
DJ Eddie!
machgo5go's Avatar
Thank you, you hit the magic work" Trim off"! The OEM front side wing's barge board tabs were there which is why I could not understand how your carbon spacers can be fit it flush under the T-plates and now I know. Now I can feel PN rear pods springs is raised higher to be more taught onto the chassis. Can't wait to see how it handle on track esp. now protected along with your V1 Front wing!
IMO, I think it maybe good idea to include some kind of simple installation instructions in your products since you do make great product from a one man band operation!
AMZ Benz TC 8500KV
DG DESIGNS
Old 2010.07.13, 10:19 PM   #19
MantisMMA
tire schredder
MantisMMA's Avatar
Not sure what your setup is but you don't need the side springs. Most of us are simply using the kyosho DDS and the t plate. I think if you use the side springs it will be too stiff and may chatter. I have even used just a shock and t plate and it worked good. It is my intention to do some write ups on I stallation but I just get overwhelmed with stuff to design /make on a daily basis! I am gonna make my team drivers do write ups for me!
MantisWorx
www.rcshox.com
Marcus Williams
Old 2010.07.13, 10:46 PM   #20
machgo5go
DJ Eddie!
machgo5go's Avatar
Not sure what your setup is but you don't need the side springs. Most of us are simply using the kyosho DDS and the t plate. I think if you use the side springs it will be too stiff and may chatter. I have even used just a shock and t plate and it worked good. It is my intention to do some write ups on Installation but I just get overwhelmed with stuff to design /make on a daily basis! I am gonna make my team drivers do write ups for me!
My set up is still very primitive since I started with a raw SP1 edition chassis kit so I am still awaiting for the Kyosho DDS to arrive soon which now installed your T plate along with PN pod & a Speedy AD motor along with a Kyosho diff. I am still in question what is the best motor to run in F1 Mod in pending to try out a 43 T if I can get this chassis tuned.
AMZ Benz TC 8500KV
DG DESIGNS
Old 2010.08.24, 01:35 AM   #21
tudor_47
tudor_47's Avatar
I have received the T-plate and I am mounting it now... looks good.
/Johnny
Get a P28
Old 2010.08.30, 11:53 PM   #22
fascinate22
Guest
Posts: n/a
hey!
thanks for the ;post
Old 2010.09.05, 07:10 PM   #23
kromie101
kromie101's Avatar
well,just ran my new f-1 and it felt pretty good to me. landon said it would be a whole lot better with a mantis t-plate.i bought one and i'm gonna try it in a few days. i might have got bit by the f-1 bug.
kromie101 is offline   Reply With Quote
Old 2010.09.08, 01:30 PM   #24
donnah246
Guest
Posts: n/a
hey
thanks for post
Old 2010.10.08, 01:31 PM   #25
MantisMMA
tire schredder
MantisMMA's Avatar
Just in time for the worlds!!! i am releasing super soft T plates monday, they are on the machine right now and will be complete today. they are .5mm thick and will increase rear traction even more!
MantisWorx
www.rcshox.com
Marcus Williams
Old 2010.10.08, 04:03 PM   #26
lfisminiz
lfisminiz's Avatar
Marcus, save 1 for me.
Old 2010.10.13, 08:32 PM   #27
MantisMMA
tire schredder
MantisMMA's Avatar
the soft plates are ready, just order the t plate as per norm but specify which one you want.
MantisWorx
www.rcshox.com
Marcus Williams
Old 2011.03.08, 09:03 PM   #28
MantisMMA
tire schredder
MantisMMA's Avatar
G10 plates in the works, should be ready in a few weeks!
MantisWorx
www.rcshox.com
Marcus Williams
Old 2011.03.08, 09:09 PM   #29
MantisMMA
tire schredder
MantisMMA's Avatar
a little off topic but im hosting a national 10th scale F1 race next month
MantisWorx
www.rcshox.com
Marcus Williams
Old 2011.03.08, 09:12 PM   #30
pedrocamp
Ain'tSoldEm
Wish I could join the fun! You have some pretty cool 10th scale F1 stuff out!
High Speed Hobbies
WTB: Atomic damper plate system and car stand TannerT Mini-Z Marketplace 1 2009.07.24 06:12 PM
New pn 94mm motor- Does it fit the atm ssg 94mm damper plate system erixxst Parts and Hop-ups 6 2008.08.28 03:30 PM
Atomic Damper Plate System Fusion Mini-Z Racer MR-02 3 2006.01.11 02:13 PM
springs for atomic damper plate system? cam2 Setups 24 2004.11.30 12:51 PM
Product Review: the CLK Front Bumper Plate West.F1 Parts and Hop-ups 6 2003.02.27 10:49 PM
