Old 2010.04.07, 01:47 PM   #1
MantisMMA
tire schredder
MantisMMA's Avatar
MantisWorx F1 rear wing mount
if you press the wing down at any angle with your finger you will see that the chassis actually rises up and even if it may or may not make a difference its still wrong! so what i have come up with is a mount that screws into the chassis. it will work with any motor mount and it will work with the stock wing. you may have to re-route your wires to clear.
i have found that the best way to install it is to get some thin double sided tape and after removing the wires or what ever is needed to allow you to stick the mount onto the chassis. after its stuck take a .062 drill and drill through the chassis, remove the mount and the tape, install provided spacer (approximately .125 tall) and screw down. now you have maximum downforce!
i am sending these out to a few racers for testing so once i get feedback from them and get hardware in they will be up forsale for 18.00
MantisWorx
www.rcshox.com
professional RC products
Marcus Williams
Old 2010.04.07, 01:49 PM   #2
i like the idea a lot. agreed, motor wires are likley going to be the biggest obstacle as they are difficult to deal with anyway.
Old 2010.04.14, 10:31 PM   #3
J-Milz
J-Milz's Avatar
I received my new Mantis rear wing in Delrin today. To my suprise it weighs 11g just like the stock wing on my F1 Ferrari. That's a bonus because it looks 100% better than stock. Can't wait to paint it up and test it on my F1.
PAYNE RACING
Action RC ALUMNI
J-Milz is offline   Reply With Quote
Old 2010.05.13, 02:41 AM   #4
tudor_47
tudor_47's Avatar
Are the mounting points at the centre of the springs in the motor mount?
/Johnny
Get a P28
Old 2010.05.13, 10:18 AM   #5
MantisMMA
tire schredder
MantisMMA's Avatar
pretty close to it, the best way to do it (instructions will be on the website next week) is to get some double sided tape and tape the mount down to the chassis and drill through the holes that are already in the mount, countersink from the bottom so you can still use side springs. remove the tape and mount using supplied hardware.
MantisWorx
www.rcshox.com
Marcus Williams
Old 2010.05.13, 03:13 PM   #6
tudor_47
tudor_47's Avatar
"countersink from the bottom"
was all I needed, Strange I did not think of it?
Thanks!
/Johnny
Get a P28
Old 2010.06.09, 06:28 PM   #7
tudor_47
tudor_47's Avatar
Hi
I have tonight mounted my MantisWorx rear wing mount....
It was an big job as it will not fit under a original body. The body needs to be remodelled in the rear and parts of it must be cut of to acomodate the new wing mount and its fasteners. I will post a picture of my mounted wing mount at a later time.
/Johnny
Get a P28
Old 2010.06.10, 01:58 AM   #8
tudor_47
tudor_47's Avatar
Originally Posted by tudor_47 View Post
Hi
As promised here is a picture of the modifyed body.
/Johnny
Get a P28
Old 2010.06.10, 09:09 AM   #9
MantisMMA
tire schredder
MantisMMA's Avatar
There ya go! looks good. maybe its a bad angle but it looks like the motor mount is angled up. set the rear suspension up so that it "sags" a little. it may just be a weird angle from the pic. when you get a chance post a pic without the body.
MantisWorx
www.rcshox.com
Marcus Williams
Old 2010.06.10, 10:43 AM   #10
tudor_47
tudor_47's Avatar
you're right it did angle up as the springs were not in.... (side springs) It is now alot better and it feels good, I hope it stays good when testing starts on saturday.... for BTE on Sunday.
/Johnny
Get a P28
Old 2012.03.12, 04:00 AM   #11
outlaw-star
Hi
Has anyone tired this with R246 DPS?
Cheers
outlaw-star is offline   Reply With Quote
December 3hr Endurance! Programmers Stafford Mini Z Racers England 26 2009.08.22 06:20 PM
Vital Statistics arch2b Autoscales, Bodies, Cars and Drivers 40 2007.08.14 09:30 AM
mr02 rear mount chassis herman Mini-Z Racer MR-02 12 2004.05.29 10:30 AM
Rear Wing mailboxck Custom Bodies 40 2003.10.21 10:29 PM
F1 Big rear Wing e_lm_70 Mini-Z F1 MF-010, MF-015 2 2002.11.20 07:16 AM
