Old 2012.01.22, 02:49 AM   #76
blt456
Originally Posted by phea View Post
Is the option key for this product out yet? (Optional 0.5,1.5,2.0 and 2.5 deg Key).
Also how do you tell what caster angel the car is at? I noticed there is some of the caster plate showing in front or behind (depending on the orientation) the sliding camber arms if your looking above it. I'm assuming if you see the the plate in front of the arm is 4 caster?
For 2 degrees, when the front of the car is facing you, the bottom plate and the arm should be flush. When you have 4* of castor, the bottom plate should stick out a little bit when the front if the car is facing you.
blt456 is offline   Reply With Quote
Old 2012.01.22, 08:38 AM   #77
unearthed name
feel it with your finger nail. if your nail snagged the front, it's 4. if you don't, it's 2.
Old 2012.04.12, 03:23 AM   #78
mitchy2759
hi guys. i just install this item on my mr 03. can anyone teach me how to use the key chamber?
sorry for such a dumb question.
i try to search the guide for this but apparently its gone already.
thx for the help
mitchy2759 is offline   Reply With Quote
Old 2012.04.12, 08:57 AM   #79
Christopher Rc
the small holes on the inside of the camber key represent the amount of camber, if theres's 2 holes then its's 2 degrees camber, :P
you need to detach your upper suspension arms, loosen the four screws at the top of the brace ,and you'll need to mount the hinge pin screw in the position you want them in on the camber key. Then mount the key on the chassis like this:
once it's in position you will ned to tighten the four upper screws before removing the tool.
Christopher Rc is offline   Reply With Quote
Old 2012.04.12, 10:41 AM   #80
mitchy2759
thx christopher.....i'll try it soon.
Old 2012.04.20, 04:44 AM   #81
mitchy2759
can i ask if everyone installing this on top of the standard front cover?
i did that, just cutting the part where holding the pin, but i notice when i tighten all the screw, the bar will not be in a horizontal position (not straight).
any help? thx
Old 2012.04.20, 08:59 AM   #82
CristianTabush
CristianTabush's Avatar
Yes, it is set on the standard plastic piece.
Make sure the holes on the chassis itself don't have any burrs or irregularities. The chances of a defective base plate, while possible, are less likely than a deformed plastic chassis.
Cristian Tabush
REFLEX RACING USA
http://www.reflexracing net
Old 2012.04.24, 12:18 AM   #83
glider
I do not see this product offered on the Reflex site anymore. Is it being distributed elsewhere or is discontinued and perhaps about to be replaced by a new product?
Last edited by CristianTabush; 2012.04.24 at 01:35 AM. Reason: oops meant to hit quote...
glider is offline   Reply With Quote
Old 2012.04.24, 12:25 AM   #84
chad508
chad508's Avatar
http://www.reflexracing.net/Reflex-R...-Key_p_81.html
they show out of stock but should be back in shortly
PN Racing
R1Wurks
LET's Go Racing
DG Designs
Old 2012.04.24, 01:35 AM   #85
CristianTabush
It's just out of stock. We are hoping to get the new production in about 2 weeks. So sorry for the delay, our factory just takes too long these days. We are moving all our new product ventures to a different vendor as we speak. This way we can deliver new products much quicker.
Cristian Tabush
REFLEX RACING USA
Old 2012.04.25, 12:52 AM   #86
glider
Sounds good! Thanks for the update.
Old 2012.10.30, 07:31 AM   #87
Originally Posted by chad508 View Post
just got one of these... checked out the instructions on the link above... but it seems it doesn't work...
any step by step instructions/pics?
are they still selling this part?
anybody know if rr is still in business? i haven't seen cristian post in a long time...
Old 2012.10.30, 10:24 AM   #88
Rune
Mini-Z Norway
Rune's Avatar
This part are still sold.
Instructions seems to be down, but take a look here to see if this can help you out.
http://www.mini-znorway.com/2010/08/...ble-upper.html
RR are still in business, but Cristian are quite busy these days so I guess that is why he are not that often in here
BR
Rune
Mini-Z Norway
Old 2012.10.30, 10:30 AM   #89
i don't think there is concern of RR not being in business, just it's commitment to mini-z now that they've moved on to large scale platforms.
Old 2012.10.30, 01:20 PM   #90
TheRinger
THATS HOW I ROLL
TheRinger's Avatar
Go to the manufactures section to Reflex Racing thread raised lower tower bar set for MR03 question page 2 and Cristian explains the reason for why a lot of mini z stuff is out of stock.
Awesome RC Racing R.I.P
PN MR03 Tower Bar benmlee PN Racing 8 2010.09.04 11:11 AM
PN MR03 Tower Bar and Lower Bar Half PN Racing 4 2010.04.14 08:40 PM
PN Racing MR02 Front Narrow Tower Bar & Lower Bar Set rogarvay Mini-Z Racer MR-02 3 2009.02.22 11:39 PM
PN Front Caster Tower Bar Version 2 benmlee PN Racing 1 2008.09.28 03:53 AM
