Old 2001.12.11, 11:06 AM   #1
Kevin
Turbo and/or XSpeed?
I'm thinking about increasing the speed of my Mini-Z (if it isn't fast enough already). I've been reading and I see there look to be two options, the XSpeed motor and/or a turbo unit. The motor is self explanatory but I'm not so sure what the turbo does. What does it do? Does it require other modifications like adding more batteries or will it work with the standard 4aaa's. What kind of speed gains will I see from these? Will it/they wear down the batteries quicker? Sorry for so many questions. I guess I don't really need any of this stuff but the Mini-Z is so much fun!!!
Kevin
Kevin is offline   Reply With Quote
Old 2001.12.11, 11:13 AM   #2
Russ
Super Moderator
Russ's Avatar
Both will wear down the batteries quicker, I'd say around 15 minutes less runtime each, mabye a little less. It also has alot to do with your driving style, but you get the idea.
the X-Speed is a great all-around speed/acceleration hop-up, while the turbo is mainly for acceleration. From what I've noticed though, the turbo helps more for acceleration than the x-speed does. If you're going for higher top speeds, go for the X-speed, or if you're going for a little more acceleration, not much, but more speed in the end, I'd still go for the x-speed...if all you're looking for is acceleration, and mabye a small increase in top speed, go with the turbo. Or you could get the best of both worlds and go for both
I kind of look at it like this, for the speed/acceleration of the mini-z, there are 3 levels. the 1st level is stock. The 2nd level is adding either the X-Speed, or the turbo. The 3rd level would be adding both the X-Speed and the turbo.
Hope this helps, I'm sure I've left out some stuff, help me out guys!!
Russ
Old 2001.12.11, 11:14 AM   #3
Russ
Super Moderator
Russ's Avatar
now that I think about it, 15 minutes each is kinda harsh, I'm withdrawing my statement and saying 5 - 10 minutes loss each item added.
Russ
Old 2001.12.11, 12:28 PM   #4
mini-z
Administrator
mini-z's Avatar
I was just about to mention that, I think 30 minutes is rather an overestimate, in my experience it's about 10% less with the turbo on (which is maybe 6 minutes or so). I still get about an hour or so under heavy driving with the X-Speed and Turbo installed.
Old 2001.12.11, 06:22 PM   #5
NOMOTORLIMIT
nomotorlimit@hotmail.com
NOMOTORLIMIT's Avatar
I'm on the same page as Russ. I would get both. Turbo does make a difference.
http://www reflexracing net
Old 2001.12.11, 06:55 PM   #6
T Man
Mini-Z Sensei
T Man's Avatar
No way!!!!!! Don't get the turbo! Get the SUPER turbo. lol
T Man is offline   Reply With Quote
Old 2001.12.11, 07:09 PM   #7
NOMOTORLIMIT
Post
Better yet, like what Russ did, he put a NOS in his car.
Old 2001.12.11, 08:14 PM   #8
Russ
Super Moderator
Russ's Avatar
Hehehe, I wouldn't recommend it...it's a royal PAIN finding someone to fill a bottle that small, much less pressure test it!!
LOL
Russ
Old 2001.12.12, 03:33 AM   #9
putting in a turbo will also allow you to use other motors if you get the model that offers short circuit protection... it helps protect your esc/circuitboard against damage from using higher rated motors... i would suggest using the x-speed for reliability (vs. the other motors that are out there)... unless you're a serious racer, don't invest in a turbo just yet.
Old 2001.12.12, 03:03 PM   #10
T Man
Mini-Z Sensei
T Man's Avatar
You really put NOS in your car? Sweet.
Old 2001.12.12, 03:27 PM   #11
Russ
Super Moderator
Russ's Avatar
nah, just a sticker of a little nos bottle on my turbo
Russ
need your opinion.....external turbo......internal turbo....!!!?!?! mclaren757 Mini-Z Science 16 2005.04.28 07:44 PM
turbo on the monster (or OL) PAULANGELO Mini-Z Monster MM-01 0 2004.03.21 07:59 PM
fet vs turbo + motors! OverRev Motor Tech 6 2002.11.23 09:11 AM
Eagle Turbo Warning avitt Mini-Z F1 MF-010, MF-015 36 2002.10.15 08:33 PM
choosing the perfect turbo... Sharpshooter Parts and Hop-ups 26 2002.02.21 03:26 AM
