Old 2010.10.09, 08:03 AM   #1
banquer
banquer's Avatar
Multi-option rear suspension compatibility
Hi Cristian!
Which motor mount are compatible with multi-opcion rear suspension to use tri-damper system?
King regards from Granada (Spain)
Club Deportivo Micro RC Granada
http://www.microrcgranada com
Futaba 4PK and KO901SM inside!
Kyosho MR03 Ferrari F430
Kyosho MR03 Mercedes C9
banquer is offline   Reply With Quote
Old 2010.10.09, 09:02 AM   #2
CristianTabush
CristianTabush's Avatar
If used as a disk damper, it works with most (if not all) mounts out there. Otherwise, as a tri-shock it has to be used with the PN 94-98 V3 mount (with long arm) or their newest 94-96mm mount. Our new motor mount, which is due in about 2 months, will also be compatible.
Cristian Tabush
REFLEX RACING USA
http://www.reflexracing net
Old 2010.10.09, 09:08 AM   #3
chad508
chad508's Avatar
ct what weight oil do you recommend to start with in the kyosho oil shock when used as a tri damper? no disk just shocks.
PN Racing
R1Wurks
LET's Go Racing
DG Designs
Old 2010.10.09, 10:16 AM   #4
CristianTabush
I personally use Sweep Racing 450 cst oil. This is about the equivalent of Associated 35 wt oil. I make sure that I fill it up to the brim and then bleed it out so that the shock shaft pushes out 75% of the way. This is the rebound, and yes, it is quite a bit, but I like how it feels. It makes the car accelerate much harder.
As a little side note, please note that this is meant to be used as a DPS or Tri-shock, not a combination of both.
Cristian Tabush
REFLEX RACING USA
Old 2010.10.09, 11:30 AM   #5
chad508
chad508's Avatar
thanks. any idea what comes with the shock from kyosho? the one i have has that oil in it, and im just trying ro get a comparasion.
PN Racing
R1Wurks
LET's Go Racing
DG Designs
Old 2010.10.09, 12:07 PM   #6
CristianTabush
Kyosho comes with 200 cst I believe.
Cristian Tabush
REFLEX RACING USA
Old 2010.10.22, 10:56 AM   #7
pedrocamp
Ain'tSoldEm
Ran the kit last night at High Speed in NC as a tri-shock with a K yellow main shock and was very happy with the feeling it gave the car. I have been running a DIY side damper with the K-yellow main shock for a while, which worked well, but the car transitioned faster and returned to center better with the tri-shock setup. Thanks RR for a nicely engineered product.
High Speed Hobbies
Old 2011.03.22, 11:01 AM   #8
hrdrvr
hrdrvr's Avatar
Any one have any idea about the thread sizes on these shock bodies? I have ruined three of them now just trying to turn the nut. Today it was a brand new one.......
Landon
LET's Go Racing!
Old 2011.03.22, 12:34 PM   #9
VAzRACER
Team Reflex
VAzRACER's Avatar
3mm. You can get the tap and die on tower hobbies for about 5 bucks each. Well worth it though.
Matt Ward
Old 2011.03.22, 12:51 PM   #10
hrdrvr
hrdrvr's Avatar
Just found out.....ended up buying a 2.5 first, cause one of my buddies said it was smaller than 3mm. Oh well, I have both now The shocks after running one pass through the tap and die are worlds different! Well worth the $20 I paid for the three items....
Anyway, thanks Matt!
Landon
LET's Go Racing!
Old 2011.03.22, 01:17 PM   #11
chad508
chad508's Avatar
oops...............
PN Racing
R1Wurks
LET's Go Racing
DG Designs
Old 2011.03.22, 01:21 PM   #12
hrdrvr
hrdrvr's Avatar
lol, It only cost me an extra $8 It worked out better anyway, cause they didnt have a die for the 2.5
Landon
LET's Go Racing!
Old 2011.05.21, 12:24 PM   #13
Hiroser
Talking oil and grease
Hi CT, I'm running a full RR MR-03 and i am very happy with it!
i just miss the motor mount that will be the cherry on top of the cake
What grease would you suggest for the side shocks?
At local RCP,which has med-low grip, i am ok with Kyosho 5K,
in the K top shock i use 400 cst, don't remember which brand.
next month i will run a big event in Latina, not so far from Rome, there will be a huge track with ton of grip.
what range of grease and oil do you recommend to bring?
Thanks
Sergio.
www minizracing it
Hiroser is offline   Reply With Quote
Old 2011.05.21, 12:55 PM   #14
CristianTabush
I run 400-500 CST, depending on how bumpy the track is. The smoother, the heavier I go.
On the side shocks, I pretty much always use 15000 wt grease. Only when the track is super bumpy or the grip is poor will I go anything lighter. This is with the Kyosho Colored Diff Grease. I don't know about other stuff, if it is thicker or how it compares.
Cristian Tabush
REFLEX RACING USA
Old 2011.05.21, 01:01 PM   #15
Hiroser
thanks for the quick replay!
www minizracing it
XMod Generation 1- Rear Right Suspension Binding Flat 4 Racing Xmods 5 2007.03.07 09:44 PM
Sticky front suspension chelboed Mini-Z Overland MV-01 3 2003.07.15 05:32 PM
Repairing the rear suspension mount Mondo Mini-Z Overland MV-01 4 2003.02.20 09:26 AM
rear suspension scsi Parts and Hop-ups 0 2001.12.21 10:42 PM
Suspension and handling Shrubba FAQ 4 2001.11.29 11:54 AM
