Old 2011.11.07, 09:43 PM   #16
unearthed name
hi chris, i tried to run the multi option rear suspension as a DPS on the RR motor mount. however i found that the damper post is waaaaay to high for the bottom spring of the DPS. i end up compressing the bottom dps spring, and i don't like it. any suggestion to have both bottom and upper spring has zero pre-load?
Old 2011.11.07, 10:34 PM   #17
Is the Damper arm on the motormount set to the lowest position?
Old 2011.11.07, 10:39 PM   #18
CristianTabush
CristianTabush's Avatar
Flip the post upside down, or raise the damper plate or both.
Cristian Tabush
REFLEX RACING USA
http://www.reflexracing net
Old 2011.11.07, 10:41 PM   #19
unearthed name
yes.
ok, i'll try doing it. thank you chris
Old 2012.01.09, 02:33 AM   #20
BrandonGR
I have a question about the rear shocks. Will the Atomic AWD151 set work to replace the plastic pieces? The plastic shocks are too hard to adjust, and I don't have a die kit to re-thread them. Is the alloy set any smoother? Anyone know how much more the alloy pieces weigh when compared to the plastic?
BrandonGR is offline   Reply With Quote
Old 2012.01.09, 05:29 AM   #21
unearthed name
My first impression is no, since they have different ball joints. But please somebody says otherwise. I would like to use the metal one as well.
Old 2012.01.09, 08:17 AM   #22
chad508
chad508's Avatar
it fits just fine but the shocks are not designed to sit at any angle. basically they are designed to move straight up and down with no pivoting at all. i bought 3 sets to try this out and came up empty handed.
PN Racing
R1Wurks
LET's Go Racing
DG Designs
Old 2012.01.09, 07:21 PM   #23
BrandonGR
Thanks chad508. Has anyone tried mounting the PN TDS dampers MR2990?
Old 2012.01.09, 07:27 PM   #24
lfisminiz
lfisminiz's Avatar
You can do that. You need to cut the male and female end shorter on the PN side shocks.
Old 2012.01.09, 08:37 PM   #25
chad508
chad508's Avatar
just be careful when cutting if you go to short they will pull apart if the car flips and the spring will go flying. its a bad way to end a race.
PN Racing
R1Wurks
LET's Go Racing
DG Designs
Old 2012.01.09, 10:05 PM   #26
lfisminiz
lfisminiz's Avatar
Like Chad said....you might want to get more than 1 set to experament till you get right length.
Old 2012.01.09, 11:23 PM   #27
unearthed name
CAn we use the frp ball joint in the metal sas shock?
Old 2012.01.10, 12:07 AM   #28
chad508
chad508's Avatar
No the ball is smaller and mounts in the shock completely different from the plastic ball. The metal shock has a collar that goes on first then the shock and then the ball goes through the shock and is all tightened together with a nut. Basically the shock is sandwiched between the collar and the ball
PN Racing
R1Wurks
LET's Go Racing
DG Designs
XMod Generation 1- Rear Right Suspension Binding Flat 4 Racing Xmods 5 2007.03.07 10:44 PM
Sticky front suspension chelboed Mini-Z Overland MV-01 3 2003.07.15 06:32 PM
Repairing the rear suspension mount Mondo Mini-Z Overland MV-01 4 2003.02.20 10:26 AM
rear suspension scsi Parts and Hop-ups 0 2001.12.21 11:42 PM
Suspension and handling Shrubba FAQ 4 2001.11.29 12:54 PM
