Old 2012.02.29, 08:31 PM   #121
CristianTabush
CristianTabush's Avatar
How are you having trouble fitting it? What is not fitting? So far, all the motors we have tested have fit on the car.
The motor plate is not currently available separately, but we are looking into getting some made.
Cristian Tabush
REFLEX RACING USA
http://www.reflexracing net
Old 2012.02.29, 10:04 PM   #122
r46
r46's Avatar
I'll have a few plates when available so motor swaps be done within min or so.
the chilli can face tat short compared to 130 atomic & pn cans which fit superb but with chilli the plate pulls away from can when tighten up plate retainer screw, so attempted to fit with screw loose then realised live terminal obstructed by pod an shaft. So have to get either T2 or Z2 as better fit with pod.
r46 is offline   Reply With Quote
Old 2012.02.29, 11:22 PM   #123
chad508
chad508's Avatar
sounds like either the motor can is warped or if im reading this wrong could be the screw your using is to long and bottoming out on the can. not sure if you mean the screw that mounts the plate to the pod or the 2 screws that mount plate to pod
PN Racing
R1Wurks
LET's Go Racing
DG Designs
Old 2012.03.01, 08:03 AM   #124
r46
r46's Avatar
using correct screw its the stumpy countersunk, pod ain't M1 friendly compared to 130 motors due to end ball an wire location. What motor/s using?
Old 2012.03.01, 08:38 AM   #125
chad508
chad508's Avatar
any way you can post a pic
PN Racing
R1Wurks
LET's Go Racing
DG Designs
Old 2012.03.01, 10:09 AM   #126
r46
r46's Avatar
race meet this weekend so after that i'll be pulling out motor for clean up, from which i'll try chilli install again with pics
Old 2012.03.06, 04:56 PM   #127
r46
r46's Avatar
mount works tremendously thanks CT lap times have became quickier motor runs cooler.
I've tried install of chilli with plate screw loose an positive outcome so i'll drop some threadlock onto screw so won't back off anymore (hopes meshing be ok time shall tell)
plate mounted on pn 70
static fit onto chilli
with screw tightened
Old 2012.03.06, 04:59 PM   #128
r46
r46's Avatar
loosened plate screw & removed + wire from terminal so able to install motor all went ok thus far
