Old 2010.10.19, 02:26 PM   #1
Mrs Mini-Z
Administrator
Cool US Spec MR-03 Chassis Set
Great news! The US Spec MR-03W-MM Chassis Set has hit US shores and is arriving this week. It's ON SALE NOW in the shop - be the first to get your here!!!!
Mrs Mini-Z is offline   Reply With Quote
Old 2010.10.19, 06:34 PM   #2
Mrs Mini-Z
Administrator
Here is some more detailed info about the US Spec:
Introducing the U.S. Spec MR-03 chassis set filled with tons of option parts! Just add your favorite body and hit the race track. The all new MR-03 series race ready chassis set is outfitted with only Kyosho quality option parts like a precision ball bearing set, ball differential set, rear oil filled shock set, carbon fiber friction shock set, plus tons more. Get the real race experience right out of the box with the new MR-03 U.S. Spec chassis set!
The difference of this machine will be noticed at the very first turn. The suspension stroke and camber change work in unison in the innovative front suspension to accurately trace the road surface while the adoption of a coreless motor in the newly designed digital steering servo has the model driving like its on rails with a light touch steering feel that brings the car back smoothly into line. In addition to the same low C of G from the MR-02, the narrow body styles of the MR-015 can be fitted due to the lightweight concentrated design. In fact, the MR-03 is compatible with all body styles from the MINI-Z racer series, which is perhaps the most comprehensive tribute to automotive excellence in R/C. Combine the MR-03 with your favorite car body and you have the finest radio controlled model available in style and performance. *Optional parts maybe required when fitting some bodies to some chassis types.
Available: October 2010
Features
* VCS (Variable Camber Suspension) - Upper arms connected to king pins and knuckles with ball links allow the camber angle to change with suspension stroke, just like on a real car. Tire contact with the surface remains constant, even during chassis roll and suspension stroke from surface tracing. The newly developed digital steering servo uses a coreless motor that delivers quick steering response and sharp maneuverability that feels like its riding on rails. Also, the upper arm and one-piece cantilever provide ideal cushioned movement for the coil spring. In addition, the stainless steel king pin and wheel shaft delivers smooth movement for excellent running stability. Precision geometry settings eliminate toe in and toe out change during suspension stroke and produce a neutral steering feel. The innovative VCS (Variable Camber Suspension) represents a significant evolutionary step in the history of the MINI-Z.
* Digital Steering Servo - The powerful position retention and movement of the digital servo is enhanced with the adoption of a coreless motor that provides instantaneous pick up and stopping. In addition, the newly developed steering gear unit has 3 times the gear ratio of previous versions for greater power in holding its position so it holds its line firmly in the face of kickbacks from the road surface and also delivers even more precise movement and response.
* Battery Layout - Same battery layout as the MR-02 chassis achieves a low center of gravity with a main chassis width equal to the narrow MR-015.
* Compatible With All AS - The main chassis is compatible with all MINI-Z ASC (Auto Scale) ranging from MR-015, MR-02 and AWD. Pick and choose from any body in the Mini Z Auto Scale body series, there are 100's of bodies to choose from. *Special motor case and differential gear assembly maybe required to fit some body styles.
* RA-22 2.4GHz Technology - Equipped with the new next generation RA-22 2.4GHz R/C unit specially designed for the MR-03. Requires no frequency bands. Simply switch power ON and enjoy safe and stable control. SF 2.4GHz system automatically scans for open frequencies and promises safer and more secure control.
* Coreless Motor + New Gear Reduction Ratio - Digital steering servo features a coreless motor and a gear unit that has 3 times the gear reduction ratio of previous units for powerful movement and position retention.
* Adjustable Front Tread - Can be set to either narrow or wide tread by replacing the front lower and upper plates and steering tie rod. Of course the wheelbase can still be adjusted to suit certain car types.
* Endless Adjustments - Coil springs in the front suspension can be easily replaced by removing the spring stopper with just two screws. Motor mount can be easily removed and replaced to suit what ever chassis configuration you want to run from a MM, RM, HM or LM type of mount.
* Powerful Performance - FET speed control amp with more than double the capacity of previous version produces extra powerful running performance.
* Power Train - Rear power train utilizes the previous models, the MR-03 rear drive train is fully compatible with all the optional parts currently available for the MR-02.
* KT-18 2.4GHz Transmitter - Newly developed 2.4GHz R/C system requires no frequency crystals and automatically scans open frequencies to use, allowing up to 40 cars to be run together. Simply switch the power on for stable control without interference. The fastest signal processing in the history of R/C results in almost instantaneous reaction to the driver's will for a more direct control feel. By pairing the transmitter to the chassis, a single transmitter can be registered and used with multiple 2.4GHz MINI-Z models. To match the latest R/C technology, a new generation LM chassis has been developed for even greater performance. *Transmitter Sold Separately Item# 82001
US Spec. Edition
* Full Ball Bearing Set - The US Spec Edition MR-03 is equipped with a full set of precision ball bearings.
* Ball Differential Set - MZW206 ball differential set gives you full tune-ability over your diff and superior cornering control.
* Oil Filled Rear Shock - Pre-installed rear oil filled shock set plants the rear end of the MR-03 on the ground and absorbs all small bumps with authority.
* Friction Shock - The carbon fiber friction shock set gives you awesome stability and combined with the oil filled shock the results is superior traction control.
* Front Spring Set - MZW401 Front spring set is included for endless tuning options.
* Rear Carbon Suspension Plate - The MR-03 US Spec comes equipped with the softest carbon T-Plate for better handling. Medium T-Plate and Hard T-Plate are also included in this chassis set.
* Long King Pin Ball - You also get the new longer king pin ball for the front suspension pre-installed.
* Blue Nylon Nut - You also get some cool blue aluminum nylon wheel nuts to finish this chassis off.
Chassis Set Contents
* RM specification power unit (included)
* MM specification motor case (installed)
* Lower and upper plate for narrow tread (front), steering tie rod (included)
* Lower and upper plate for wide tread (front), steering tie rod (installed)
* Front suspension spacer for adjustment
* 6T. 7T. 8T. 9T Pinion Gear
* Wheel wrench
* Pinion removing tools
Pairing stick
Technical Data:
Length: 125-133mm (4.9-5.2in)
Width: 65-76mm (2.5-2.9in)
Height: 34-35mm (1.3-in)
Chassis Type: MR-03W-MM
Wheelbase: 86-106mm (3.3-4.1in)
Weight: 130g
Required For Operation
* ASC Body (Mini-Z Auto Scale Collection Body)
* Perfex KT-18 Transmitter Sold Separately #82001
* Tires & Wheels
* 4 x AAA-size alkaline batteries for transmitter (KT-18)
* 4 x AAA-size alkaline or NiMH batteries for chassis.
Optional
* PEK00580 (900HV AAA NiMH Rechargeable)
HTML code is On
F1 Carbon Friction Plate Shock Set on 27MHz Chassis? rensuchan Mini-Z F1 MF-010, MF-015 10 2011.11.06 07:07 AM
FS - Brand New MR-03 chassis set RRRoy23 Mini-Z Marketplace 3 2010.07.06 11:03 PM
FS: 3 built AM MR-02 chassis with entire accessory collection builthatch Mini-Z Marketplace 10 2010.03.08 08:08 PM
FS: MA010 Chassis Set Blue/Gray w/ Bearings Old Crow Mini-Z Marketplace 12 2007.08.28 10:39 PM
What's included in the MA-01 chassis set pchan0 Mini-Z AWD MA-010, MA-015 9 2005.11.29 07:37 PM
