Old 2010.11.26, 08:20 AM   #1
addicted
Everything must go
Contact: PM
I really don't have the time to even make the fortnightly meet at Hereford, so i don't see the point in keeping all the stuff i have, as it's just money wasting away, so it's going to be going up for sale!
Postage can be arranged dependant on the items you have, also i will be going up to Stafford/Hereford if enough if sold there, so no postage required!
Items NEW IN PACKAGE
  • Atomic 8* Radial Groove (W) x3 (RRP 2.33)
  • Atomic A.W. Groove N (30*) (RRP 2.90)
  • Atomic Rear 20* COMP
  • Atomic Slick R 30* N x2
  • PNRacing RCP Slick Front 8*
  • Atomic MR-02/015 Delrin Gear (41T) (RRP 4.64)
  • Atomic AWD Centre Drive Spur Gear (94mm) set (RRP 3.34)
  • Atomic AWD Centre Drive Spur Gear (98mm) set (RRP 3.34)
  • Atomic 21.5mm T.S Rims (W) +3 Silver (RRP 2.03)
  • Atomic 21.5mm T.S Rims (W) +3 Black (RRP 1.46)
  • Atomic 21.5mm T.S Rims (N) +1 Silver (RRP 2.03)
  • Atomic 21.5mm T.S Rims (N) +1 Black (RRP 1.46)
  • Atomic Ultra stainless steel kingpins (RRP 3.77)
  • Atomic AWD Spring (SE) #2 orange (RRP 1.01)
  • Atomic MR-02 Ball Diff Titanium Shaft (RRP 9)
  • PNRacing MR02 Front Racing Suspension Spring Set 5.22)
  • Atomic 2mm aluminium lock nuts (black)
  • Atomic C-Ring for kingpin)
  • AutoScale Honda S2000 (yellow) (opened)
  • AutoScale Merc Mannesmann D2 (Silver) (opened)
  • AutoScale Xanavi Nismo GT-R 2008 (MR-03 Default) (opened)
Open to SENSIBLE Offers!
All the other items will eventually appear in the next couple of posts!
All items will be sent second class, recorded will be an extra 74p!
Used Items
Batteries:
  • 4 Matched sets of Orion 900HV, used max of 10 times. sold
  • 2 matched sets of Orion 750SHO, used max of 3 times. sold
  • 3 matched sets of Atomic generic (but good), used up to ~40 times.
  • 1 set of Fujicell 1100's
Cables:
  • Custom made 2.4Ghz ICS Cable sold
Tags:
  • 2x Speedway Core timer tags
Motors:
  • PNWC 70T Motor (x2) 1 not worn in sold
  • atomic Stock R Motor sold
  • Kyosho X-Speed V motor
  • 1 Stock motor
  • Atomic BB Motor (yellow label)
  • Custom built motor reached 75KPH! (silver brushes, HE BB Motor case), customized spindle
Shells:
  • Ferrarri Enzo (custom black & white finish) with Clip
  • Renaultsport Megane Trophy (with clip and 2 sets of wheels (white + silver) with clip sold
  • Xmods Mitsubishi Evo (8 i believe?) with the bodykit set) with clip set for pan car
  • Mazda MR2 in purple with clip
  • Beater Suburu SXI ( i think ) in white with clip
Spare Parts:
These will be ordered from left to right, top to down.
1st Row:
  • GPM AWD Alloy Set; battery case, rear lower section, front top section, 2 0deg knuckles, 0 deg toe bar, servo saver
  • Complete AWD offset wheel set (Kyosho i believe)
  • Team Atlas Wheels (these are rare & lovely) 0 offset wide x4
  • selection of ASC tyres, useful for drifting
  • MR-02 Accessories set in blue
  • MR-02 Accessories set in Yellow
  • Drift tyre set (2x N and 2x W)
2nd Row:
  • Selection of 3Racing alloys, both wide & narrow
  • Atomic AWD set; all 4 of the motor gears, a1/b1 + a2/b2 of the motor holders in metal
  • selection of stock wheels, bushes, knuckles and wheel nuts.
  • 4 MR-02 wheels (2N, 2W with AtomicRadial 8*'s) all +3 offset
  • 3Racing AWD Spur + Motor gear full set
  • Selection of decent tyres, including some A.W groove and a pair of rear Atomic Slick's
  • TRP Belt Drive set - only needs a couple more ball bearings to be fully working, never used! Hear great things though
  • stock motor as listed above
3rd Row:
  • Infra-Red lap counter cable
  • PNRacing 2.0 deg knuckles for AWD x2
  • Atomic Light System
  • Kyosho X-Speed V as listed above
  • PNWC 70T as listed above
  • Atomic BB (yellow label)
  • Atomic DPS kit with top mount (98mm)
4th Row:
  • Assorted screw set for MR-02 (absolutely loads spare)
  • Atomic DPS system (94mm)
  • Atomic 0 degree knuckles x4
  • Atomic 98mm conversion kit + drift shaft holder (not sure what it's called now)
  • Various MR-02 suspension washers with a couple of pinions
  • 2 fiberglass plates + ccg
  • various screws +springs for the DPS systems (getting both and the atomic motor mount is advisable for the best combination)
  • Atomic Light weight MM motor mount latest ver
5th Row:
  • Kyosho standard AWD diffs (1 has the gears taken out and replaced with thick oil to more accurately simulate drifting, gears included sold
  • 2 Atomic Spring sets
  • Complete AWD chassis set with LOTS of extras sold
  • 2 Atomic +3.5 W wheels
  • 2 sets of crystals, 27.075 and 27.195
  • One of the best, if not the best motor you'll ever see! also listed in motor section!
Cars:
Car 1 - 02 Racer Pro
Transparent 02 Chassis
PNRacing Double A-Arm front suspension
Kyosho Red ToeBar set
Reflex Racing Abec 5 bearings
Fetted 02 non-2.4ghz board with 2x2 Atomic Extreme Power Fets
Kyosho Top Oil-Filled Shock
Atomic SSG Plate @ 94mm setup currently
PNRacing MM Motor mount (v5 i think?)
Kyosho servo gear set
Kyosho server saver
Atomic Racing Titanium Diff (rebuilt) with PNRacing 64Pitch set
Atomic Wheel Nuts
Stock Front Wheels, 0N with Atomic Groove 30's
Atomic Rear Wheels, i believe +3 with Atomic 8* radial groove
Titanium Screws all round
Extras:
Atomic Springs
Atomic Wheel Bearings
Atomic Titanium Screws
Kyosho Full Red Toebar set
Full PNRacing 64Pitch Set
Due to the amount spent on it (~230 just parts), i'd let it go for about (UNSURE YET!)
Car 2 - AWD Racer Pro
Blue/Grey Comp Chassis with Gold Terminals
PNRacing 1.5* Front Knuckles
Atomic AWD Race Red Springs (LowDown)
Atomic Top plate SSG & Plastic
Atomic Ball diff with Thrust Bearing x2
Atomic Titanium Drive Shafts (Dogbone)
Atomic Titanium Main Shaft
3Racing Motor Mount
Atomic Pro S.A.S Carbon Fiber
Atomic S.A.S Aluminium Shocks
Atomic S.A.S Orange & Silver Springs
Extras:
Full S.A.S kit including the grease & extra springs
Full Motor Spacer Set
Full Spur + Motor Gear Set (90mm, 94mm AND 98-102mm)
Cable for Infra-red lap systems
Again, not sure on the price yet, so give me some time, and again open to offers.
Car 03 - Stock 02 Racer sold
This car sports the blue/grey chassis as standard
Everything is standard except you get tyres & wheels, all 0 offset.
Needs a board of your choice (hence my spare board, which i was going to fet)
EDIT: After checking over the car & looking for the bits to make it up, i can't find the top mount that connectors the top casing to the spring! Everything is complete apart from this
Extras:
Full 02 set of spares including RM mount, motor spacers, pinions etc.
Note: No cars come with motors, these are sold separately as you can see, allowing you to choose which one you want, if any!
Electronics:
  • mr-02 board (needs fets, can supply 2 Atomic Extreme with it) non 2.4ghz complete
  • KT-18 controller, basically like new, no marks whatsoever. sold
  • Jaguar 2ch controller (useful if you like sticks instead of a wheel) sold
addicted is offline   Reply With Quote
Old 2010.11.26, 08:20 AM   #2
addicted
Rough price list:
The price list does not show what is/isn't available so please check main list
New Items Price ()
Atomic 8* Radial Groove (W) x3 (RRP 2.33) 2 2.00
Atomic A.W. Groove N (30*) (RRP 2.90) 2.50 2.50
Atomic Rear 20* COMP 2 2.00
Atomic Slick R 30* N x2 4 4.00
PNRacing RCP Slick Front 8* 2 2.00
Atomic MR-02/015 Delrin Gear (41T) (RRP 4.64) 4.50 4.00
Atomic AWD Centre Drive Spur Gear (94mm) set (RRP 3.34) 3 3.00
Atomic AWD Centre Drive Spur Gear (98mm) set (RRP 3.34) 3 3.00
Atomic 21.5mm T.S Rims (W) +3 Silver (RRP 2.03) 2 2.00
Atomic 21.5mm T.S Rims (W) +3 Black (RRP 1.46) 1.40 1.40
Atomic 21.5mm T.S Rims (N) +1 Silver (RRP 2.03) 2 2.00
Atomic 21.5mm T.S Rims (N) +1 Black (RRP 1.46) 1.40 1.40
Atomic Ultra stainless steel kingpins (RRP 3.77) 3 3.00
Atomic AWD Spring (SE) #2 orange (RRP 1.01) 1 1.00
Atomic MR-02 Ball Diff Titanium Shaft (RRP 9.50) 8 8.00
PNRacing MR02 Front Racing Suspension Spring Set 5.22) 4.50 4.50
Atomic 2mm aluminium lock nuts (black) 2 2.00
Atomic C-Ring for kingpin) 2 2.00
AutoScale Honda S2000 (yellow) (opened) 22 22.00
AutoScale Merc Mannesmann D2 (Silver) (opened) 22 22.00
AutoScale Xanavi Nismo GT-R 2008 (MR-03 Default) (opened 25 25.00
Batteries
2 matched sets of Orion 750SHO, used max of 3 times. 15 15.00
3 matched sets of Atomic generic (but good), used up to ~40 times. 7 7.00
1 set of Fujicell 1100's 3 3.00
Cables
Custom made 2.4Ghz ICS Cable 9 9.00
Tags
2x Speedway Core timer tags 1 1.00
Motors
PNWC 70T Motor (x2) 1 not worn in 13 13.00
Kyosho X-Speed V motor 8 8.00
1 Stock motor 5 5.00
Atomic BB Motor (yellow label) 10 10.00
Custom built motor reached 75KPH! (silver brushes, HE BB Motor case), customized spindle (only just re-worn in on silver brushes) 35 35.00
Shells
Ferrarri Enzo (custom black & white finish) with Clip 15 15.00
Renaultsport Megane Trophy (with clip and 2 sets of wheels (white + silver) with clip*sold
Xmods Mitsubishi Evo (8 i believe?) with the bodykit set) with clip set for pan car 20 20.00
Mazda MR2 in purple with clip 10 10.00
Beater Suburu SXI ( i think ) in white with clip 5 5.00
Parts
Row1
GPM AWD Alloy Set; battery case, rear lower section, front top section, 2 0deg knuckles, 0 deg toe bar, servo saver 10 10.00
Complete AWD offset wheel set (Kyosho i believe) 5 5.00
Team Atlas Wheels (these are rare & lovely) 0 offset wide x4 13 13.00
selection of ASC tyres, useful for drifting 4 4.00
MR-02 Accessories set in blue 5 5.00
MR-02 Accessories set in Yellow 5 5.00
Drift tyre set (2x N and 2x W) 2 2.00
Row2
Selection of 3Racing alloys, both wide & narrow 4 4.00
Atomic AWD set; all 4 of the motor gears, a1/b1 + a2/b2 of the motor holders in metal 10 10.00
selection of stock wheels, bushes, knuckles and wheel nuts. 4 4.00
4 MR-02 wheels (2N, 2W with AtomicRadial 8*'s) all +3 offset 3 3.00
3Racing AWD Spur + Motor gear full set 4 4.00
Selection of decent tyres, including some A.W groove and a pair of rear Atomic Slick's 7 7.00
TRP Belt Drive set - only needs a couple more ball bearings to be fully working, never used!*
*Hear great things though 14 14.00
Row3
Infra-Red lap counter cable 1 1.00
PNRacing 2.0 deg knuckles for AWD x2 10 10.00
Atomic Light System 4 4.00
Atomic DPS kit with top mount (98mm) 14 14.00
Row4
Assorted screw set for MR-02 (absolutely loads spare) 3 3.00
Atomic DPS system (94mm) 8 8.00
Atomic 0 degree knuckles x4 12 12.00
Atomic 98mm conversion kit + drift shaft holder (not sure what it's called now) 9 9.00
Various MR-02 suspension washers with a couple of pinions 2 2.00
2 fiberglass plates + ccg 2 2.00
various screws +springs for the DPS systems (getting both and the atomic motor mount is advisable for the best combination) 4 4.00
Atomic Light weight MM motor mount latest ver 10 10.00
Ro5
Kyosho standard AWD diffs (1 has the gears taken out and replaced with thick oil to more accurately simulate drifting, gears included 3 3.00
2 Atomic Spring sets 1 1.00
Complete AWD chassis set with LOTS of extras 7 7.00
2 Atomic +3.5 W wheels 2 2.00
2 sets of crystals, 27.075 and 27.195 2 2.00
One of the best, if not the best motor you'll ever see!*
*also listed in motor section!
CARS
Car 1 - 02 Racer Pro 150.00
Reflex Racing Abec 5 bearings*
Kyosho server saver
Atomic Wheel Nuts
Extras:
Atomic Springs
Car 2 - AWD Racer Pro 140.00
3Racing Motor Mount
Extras:
Car 03 - Stock 02 Racer 30.00
EDIT: After checking over the car & looking for the bits to make it up, i can't find the top mount that connectors the top casing to the spring! Everything is complete apart from this*
Extras:
Electronics
mr-02 board (needs fets, can supply 2 Atomic Extreme with it) non 2.4ghz complete 20 15.00
KT-18 controller, basically like new, no marks whatsoever. 45 50.00
Jaguar 2ch controller (useful if you like sticks instead of a wheel) 12 10.00
prices can be negotiated, but if you check they are good prices!
Old 2010.11.26, 08:21 AM   #3
addicted
would also like to keep it UK-only, unless the shipping is paid @ the buyer's expense!
hope you can make sense of all the posts, i dont have time to restructure it all (original topic is at miniRC)
