Old 2011.01.04, 01:29 PM   #1
lornecherry
Porta-Trax Lead Designer
front steering servo chatter
Got the new "Tiki-Tiki" JSCC Cup MR-03. After 2 mins of running the front servo constantly chatters and is jittery when in any position. Tried binding to a 2nd transmitter and same thing. Any quick fix for this, or should I just try contact cleaner in the steering servo pot? Seems strange that the pot would be dirty right out of the box.
Lorne Cherry
R/C Track Designer
lornecherry is offline   Reply With Quote
Old 2011.01.04, 01:43 PM   #2
Traveler
of both Time and Space
Traveler's Avatar
Servo jitter is normal on the 03s. Shouldn't affect performance.
Old 2011.01.04, 04:13 PM   #3
greenepa76
greenepa76's Avatar
This is normal for digital servos.
greenepa76 is offline   Reply With Quote
Old 2011.01.05, 01:54 AM   #4
is it affecting and/or restricting any steering movement?
try 'resetting' your tx... a guy i know (with the regular kt18 and mr02 asf) had some steering issues (binding, limited steering throw on one side compared to the other)... he rebinded... and it still happened... i suggested to reset and rebind the kt18 and after that the problems were gone...
don't know if you can reset 3 channel tx's though...
dunno if this is what you're experiencing with yours though...
but if it's just some servo noise coming out in front, it's normal...
hope this helps
Servo Conversion Tutorial for MRCG's color01 GSR 5 2010.03.30 12:31 AM
Vital Statistics arch2b Autoscales, Bodies, Cars and Drivers 40 2007.08.14 10:30 AM
Kyosho Parts arrivals Tim Johnson Parts and Hop-ups 6 2006.06.06 12:00 PM
MR01 Steering Servo Needed dmc456 Parts and Hop-ups 0 2004.12.28 03:17 PM
V2 Turbo / New Steering Servo gears x777cat Parts and Hop-ups 7 2003.04.27 05:31 PM
