Old 2011.02.21, 09:22 PM   #1
lfisminiz
lfisminiz's Avatar
R246 life batts/pn charger
I got the R246 LIFE batts, harnesses (for the car), and charging cord to charge. I also can charge them on my PN charger.
Anybody know how to hook up the batts to charger? Looks like on the 246 charging cord, 1 end you can hook up to 2 batts. The other end looks like the white plug will go into the 1 PN cord (Its the bigger plug with a curcuit board with female plug ends on it). The 246 cord also has a black plug on the same end. Not sure where that goes?
THANKS.
Old 2011.02.22, 02:03 AM   #2
iruninsoga
The white plug plugs into the balancing board, the thing with multiple connectors with differing pin counts.
The black part has to be connected to the banana plug outputs. You'll probably need to make an adapter if it wasn't included with the charger.
Don't forget to set the charger correctly, for example using Lipo settings on LiFe isn't really recommended...
iruninsoga is offline   Reply With Quote
Old 2011.02.23, 01:22 PM   #3
mini-z
Administrator
mini-z's Avatar
Lightbulb
L, LMK if you weren't able to figure this out and I'll take a pic of my setup...
Old 2011.02.23, 03:05 PM   #4
lfisminiz
lfisminiz's Avatar
Dave, a pic would be nice! Im getting ready for a race and running out of time to tinker with it. Im thinking the black plug is the only question mark i have....the rest i see.
Old 2011.02.23, 05:38 PM   #5
kryten
kryten's Avatar
If you're using the pn s6 charger,it comes with the correct adaptor to charge them. You need to go into user settings then lipo(3.7v per cell),and change to life(3.3v per cell). I charge mine at 0.8a too.
Old 2011.02.23, 06:52 PM   #6
lfisminiz
lfisminiz's Avatar
What Pn cords are you using? I know the one end (246 cord), goes to the 2 batts. The other end goes into the PN connector with the multiple ends on a curcuit looking board. Now theres a black connector left (246 cord)?
Old 2011.02.24, 05:22 AM   #7
kryten
kryten's Avatar
The black connector is the charge lead,look through your charger box and you will have one with the correct end on it to connect to the black plug.
NEW PN Li-Po NiMH NiCd Charger coming soon! PNracing PN Racing 92 2012.08.22 01:10 AM
Duracell 15min charger pzchuky Batteries, Chargers and Dischargers 0 2010.10.31 12:44 PM
Batteries and charger lynnheartjoe Beginner Questions 3 2010.09.22 11:50 PM
Apple Battery Charger arch2b Batteries, Chargers and Dischargers 5 2010.08.04 09:40 AM
Backlight your ICE Charger PaulBoth Off-Topic 5 2005.11.25 07:31 AM
