Old 2011.03.11, 02:16 PM   #1
rajiex
rajiex's Avatar
No motor response
Built a 03 from all my spare parts. Burned one FET on install of a new board. Kyosho was great and sent me a new board on warranty. Put new board in, able to pair the car, have steering but no throttle. Stopped immediately, don't want to try anything till I get some help. Don't want to burn the feet. Help!!!
Raj
Action RC2]
  • MR-03 94MM Ferrari Modena
  • MR-03 94MM Nissan 350Z
  • MR-03 90MM Ferrari 355
  • MR-03 98MM Ferrari 599
  • MR-02 98MM Mosler
  • MR-02 102MM Mazda 787B
  • MA-10 94 Chevy Corvette
  • MA-10 94 Toyota Supra (Drifter)
  • MF-015 Ferrari
rajiex is offline   Reply With Quote
Old 2011.03.11, 03:12 PM   #2
hpotter
hpotter's Avatar
if motor wires are tight check the brushes in the motor--possibly no good?
DMS Racing
The premiere RC racing club in the Tri-State area
hpotter is offline   Reply With Quote
Old 2011.03.11, 06:08 PM   #3
wildthing
RC addict
1) try check the output (positive and negative) of the board if there is power using a voltmeter.
2) try to "run" the motor by powering it with a battery directly (btw is your motor stock?)... how did you burn your FET (did you install it with a hot motor)
Old 2011.03.11, 06:38 PM   #4
rajiex
rajiex's Avatar
Rebinded the car, and it worked.
I burnt the board by grounding out the motor leads. Aftermarkets tabs are a little big and I think they touched.
Raj
Action RC2]
  • MR-02 98MM Mosler
  • MF-015 Ferrari
Old 2011.03.11, 10:25 PM   #5
cosmicsoul
The Mad Mexican
Don't no a whole lot about this sort of technical stuff.
I can tell you this definately check your brushes as mentioned before. In three years I have never had this happen, but recently burned up two board due to brushes.
On one I got lucky the fetts actually fell off. The other the motor wires melted off board and burned the ever living crap out of the board looks like I cooked a greasy burger where the fetts were.
Jay Vasquez
MWG Racing
