Old 2011.03.17, 03:28 PM   #1
MantisMMA
tire schredder
MantisMMA's Avatar
Mantisworx tri-shock
just a heads up but i am working on a proper tri-shock system for the F1. my goal is to get one designed that will fit under the body and utilize the popular PN mount. so more than likey it will have some sort of cantilever design since thats the only way to get all three shock mounted fore and aft. as i start to come up with ideas i will post some of the CAD work to see what ya think! the shocks are on order and should be here in a few weeks since they are coming from HK.
MantisWorx
www.rcshox.com
professional RC products
Marcus Williams
Old 2011.03.17, 05:06 PM   #2
lfisminiz
lfisminiz's Avatar
Sounds good...Marcus.
Old 2011.03.31, 01:40 PM   #3
MantisMMA
tire schredder
MantisMMA's Avatar
shocks came in today! should have a working prototype next week!
MantisWorx
www.rcshox.com
Marcus Williams
Old 2011.03.31, 02:27 PM   #4
Traveler
of both Time and Space
Traveler's Avatar
That was quick! Look forward to see what you come up with!
Old 2011.03.31, 02:44 PM   #5
MantisMMA
tire schredder
MantisMMA's Avatar
i have been looking at it for the last hour or so and its going to be a really tight fit to get it under the body especially the Ferrari. it looks like its definately going to have to be a cantilever style and the board will need to be moved forward. i already ahve instructions on the board movement from the old cantilever setup.
MantisWorx
www.rcshox.com
Marcus Williams
Old 2011.03.31, 07:00 PM   #6
MantisMMA
tire schredder
MantisMMA's Avatar
well here is the first prototype, mild clearancing necessary on the Mclaren body, no go for the Ferrari without some bodywork (which is not hard to do). a few more dimensions to change. and then i will send out for testing.:
MantisWorx
www.rcshox.com
Marcus Williams
Old 2011.03.31, 07:48 PM   #7
lfisminiz
lfisminiz's Avatar
Looks like a cool concept. Trimming the body some isnt a big issue i wouldnt think.
Old 2011.03.31, 08:35 PM   #8
MantisMMA
tire schredder
MantisMMA's Avatar
its the only way to get it under the body. and i like the fact that it seperates up and down from sideways. hows testing going? havent heard any feedback from ya yet!
MantisWorx
www.rcshox.com
Marcus Williams
Old 2011.03.31, 10:18 PM   #9
lfisminiz
lfisminiz's Avatar
Tonight.........ill let you know.
Old 2011.03.31, 11:42 PM   #10
VAzRACER
Team Reflex
VAzRACER's Avatar
Beautiful! Thats a much easier way then how I was going about it.
I will be doing extensive testing on the new plates this weekend. We had a race last weekend and I was going to test there but didnt have time. Plus the track was green and grip was non exsistent. I'll be on a track I know well this weekend so Ill be able to really get an idea of how they work. They should compliment the tri-shock setup very well.
Matt Ward
Old 2011.04.01, 02:30 AM   #11
I really like how this is designed. There really is very little space under these bodies, and if this works the way I think it does, you fit a lot of adjustability in a small package. I look forward to testing it
Old 2011.04.01, 02:44 AM   #12
tudor_47
tudor_47's Avatar
Interested to find out how it compares to the Kyosho DPS?
/Johnny
Get a P28
Old 2011.04.20, 10:28 AM   #13
hpgod
hopefully the new gernation shocks limit over extension/droop. That was the problem with PINOYBOY and mine tri shock f1s a 2 years ago. great traction but if you had a bad wreck/traction roll the pod could droop and over extend the SAS shock would fall apart. No incidents and they were great.
But I have been running a PN pod with a lower shock mount and atomic disk damper and traction has not been an issue once all the body clearance were solved, multiple side to side issues.
atomic stock r - and fetted 2.4 board - glued tires are required
Old 2011.04.20, 11:22 AM   #14
MantisMMA
tire schredder
MantisMMA's Avatar
i did run into that when designing it, it is tricky to find the right amount of movement and spring combo. They are the same shocks used on the reflex MR tri-shock so i dont foresee that being a problem, secondly the shocks are activated by a cantilever so any up and down movement from the pod doesnt effect the trishocks at all, they only move when the pod is twisted! one thing i did find necessary is to drill a vent hole in the shock to prevent unwanted rebound.
MantisWorx
www.rcshox.com
Marcus Williams
Old 2011.04.26, 06:55 PM   #15
MantisMMA
tire schredder
MantisMMA's Avatar
well, just got the approval from Matt! it works very well, gets rid of the dreaded tweak and increased traction! so i will open up pre-order in a day or so and begin production next week.
MantisWorx
www.rcshox.com
Marcus Williams
Silicon Oil Weight(s) for Kyosho MR02 Rear Oil Shock? Felix2010 Mini-Z Racer MR-02 10 2009.04.14 03:23 PM
how to lift and lower your ol, complete instructions. james399 Mini-Z Overland MV-01 32 2008.03.29 03:19 PM
Eagle Mono Oil Shock - Help!! CedMan Parts and Hop-ups 8 2002.08.17 05:27 PM
Triple Oil Shock! jcostantino Parts and Hop-ups 5 2002.01.20 12:58 AM
roll shock v. rear shock bbc5 Parts and Hop-ups 2 2001.12.14 04:04 PM
