Old 2016.05.17, 12:54 PM   #46
lfisminiz
lfisminiz's Avatar
Originally Posted by byebye View Post
Next question is how easy is it to fit in the stock motor pods? Reason being is Washington GTG stock class does not allow allow motor mounts. I have a spare brushless motor and I'll see how it fits but I doubt it will sit normal since the pods are designed around the D shaped can.
Kris
Good ponit.
Old 2016.05.17, 01:22 PM   #47
you would have to try to slip the kyosho brushless motor casing over it or fab up your own putting a square peg in a round hole so to speak
Old 2016.05.17, 07:04 PM   #48
byebye
byebye's Avatar
We may be the only club putting brushless motors in stock pods
In the last pic you have to bore out the larger shim for the end to fit. Don't bore out too much! Notice there is a notch at the bottom. You have to file in a notch so that the motor doesn't spin inside the shim.
Kris
byebye is online now   Reply With Quote
Old 2017.03.02, 01:30 PM   #49
Traveler
of both Time and Space
Traveler's Avatar
How do the PN brushless motors fit in the newer MM2 pod? Any modifications needed?
Old 2017.12.08, 07:58 AM   #50
they seem to fit fine. they do not fit so well within the standard MM pod as the spacers are not shaped to accommodate the endbell. we'll see if we can't 3d print a solution to that problem.
Old 2017.12.08, 08:05 AM   #51
byebye
byebye's Avatar
My skills have grown! A 3d printed solution for spacers is easily achieved.
Now how do we make a set of spacers with a slight modification to the pod to accommodate a set screw for fine adjustment? ;-)
Kris
Old 2017.12.08, 08:14 AM   #52
proposed rule change
Motor - Kyosho Racer and AWD Stock motor only.
proposed changes:
Motor
Brushed: Kyosho Racer and AWD Stock motors only.
Brushless: PN 3500kv, Part Number 140035 only. Gearing limited to 8 tooth maximum.
we tested this combination from 6-9 tooth and 8 tooth places this on par with other top drivers in the class using stock brushed. I dare say brushed was still a touch faster as a result of our typical size track layout.
Old 2017.12.08, 08:23 AM   #53
Kris
it would be nice to have that level of adjustment however stock motors are not drilled and could not benefit from the feature thus making it an unfair advantage to do so for the brushless motor.
i'm sure there is a technical way to engineer the spacer to allow for shifting of the endbell position without needing to replace the entire spacer in the stock motor pod however in terms of practicality, it would seem easier to simply print a dozen spacers with slight shifts in placement. there are alloy motor pods that include adjustable endbell retainers for stock motors but these are expensive and in many cases limit compatibility with other stock parts which runs counter to the stock class program goals.
Old 2017.12.08, 01:21 PM   #54
byebye
byebye's Avatar
It's a separate discussion but I'm talking screw adjustment perpendicular to the motor. I'll draw it up and start a new thread for it.
Also, I support the motor changes.
Kris
Old 2017.12.08, 02:24 PM   #55
JB3
So the regular brushless board (MZ503)or the pro brushless board (MZ505) are good? I have the MR03VE Pro MM2 chassis set and my thought was when brushless was approved for stock i could fit the PN 3500 motor in it and be good to go.
JB3 is offline   Reply With Quote
Old 2017.12.19, 09:09 PM   #56
yes, any kyosho board is fine. be sure to take the rest of the kit back to stock no ball diff, upgrade springs, stock suspension only
our testing was done with ASF brushless. we'll see if MHS bruhsless ups the ante any for overall speed. if so, may have to kick the pinion down to 7t for MHS. we'll see and adjust as necessary. our track sizes do a very good job of leveling the field.
Old 2017.12.19, 10:07 PM   #57
JB3
Thanks you! I will make sure to take the rest of the kit back to stock as well.
Old 2018.01.22, 06:19 PM   #58
Mike Keely
We are running these every Thursday evening at Remnants track also,
DG-Designs / Brooklyn Hobbies
Old 2018.05.18, 08:24 AM   #59
As of May 17, 2018; PN PNWC 70 Turn Ball Bearing Motor (132370) is acceptable is Kyosho Stock Class.
If you have a fast stock motor, your going to run the same speed as 70T. if you have a slow 70T your going to run the same speed as a stock motor. There is variation in commercial production of the motors. Blueprinting motors has been investigated and ruled out as cost prohibitive as it would double the cost of the motor, if not more.
There are any number of variables that will make one car faster than another such as; motor selection, gear mesh, battery selection, etc. The fastest car doesn't always win the race either
The addition of 70T motor may allow us to move back to 10 minute mains which is nice as it provides a bit more time to recover should you get distracted on a bad lap. Kyosho Stock class is about consistency of driving skill vs. dominating speed. Some stock motors overheat in as much as 8 minutes which is detrimental to the driver and program.
Old 2019.12.23, 06:46 PM   #60
Updated Kyosho Stock Rules for 2020!
Key points
-PN 3500KV V3 not allowed in Stock class due to manufacturer defect
-No longer brand specific BL brushless motors, any manufacturer 3500KV or less (see Kyosho exclusion below)
-Kyosho 4100KV brushless motor will be permitted based on limited testing in December of 2019.
-Optional front springs will be permitted however limited to what is provided in Kyosho Circuit Pack upgrade parts kits. This kits are perfect upgrade kits to get you started in tuning to track conditions.
-Update to acceptable Autoscales to include GL Racing Autoscales as these are not sold in readyset or chassis set format. Note, Iwaver/Firelap Autoscales were sold in these formats thus acceptable however they are likely not easy to find anymore and to include any newer releases.
M.H.S. Racing Discussion HobbyShopOwner Mini Z Racing, Maj's Hobby Shop, Saddle Brook NJ 9983 2016.07.02 02:25 AM
2011 Stock Class Motor Rules pedrocamp High Speed Hobbies, NC 7 2011.02.23 07:55 PM
Salt Lake Mini-Z Racing Regulations briankstan Salt Lake Mini-Z 0 2008.01.17 10:56 AM
MR-02 RM Stock Racing Setup Spoon Mini-Z Racer MR-02 19 2006.05.10 06:13 PM
