Old 2011.08.09, 05:05 PM   #1
cowboysir
Advice on a resin body?
Dave,
I'd like to get advice on a Resin proto Honda HSV I've got:
I'm having trouble with the base layer of paint sticking. I've made several attepts at an even coat of white (Tamiya rattle can) before moving onto the scheme I've found to use. Certain areas seem to evade paint and some areas seem not to stick at all...
I'm wondering if I need to sand more than i did and use a primer?
thoughts?
Old 2011.08.10, 01:41 AM   #2
did you wash the body with soap and warm water prior to spraying?
the resin may still have some traces of oil on the body...
or you may have better results using an oil based paint instead of a waterbased paint...
hope this makes sense...
Old 2011.08.10, 04:31 AM   #3
unearthed name
A layer of paint primer maybe needed
Old 2011.08.10, 08:45 AM   #4
Davey G
Need a mini z Painted????
Davey G's Avatar
Hey, there are def a few tricks to painting the resin bodies. I wash the bodies with DAWN dish detergent, warm water and a scouring pad (plastic kind). Obviously making sure its dry first then I spray bomb my first color. (Createx or Faskolor paint) I lay my mask on top of the body (pre cut, NEVER take an xacto to the body or your base layer will peel) and do all my tight airbrush work. I then clear with Rustoleum Clear CC1000. So at what point are you noticing peel? I have also posted in my paint thread that I use 3m painters mask for delicate surfaces (orange core) is this what you use?
Let me know your thoughts on the above.
Dave Graboski
DG Designs
MHS is Hosting a PN Racing Mini-Z World Cup 2009 ruf993 Mini Z Racing, Maj's Hobby Shop, Saddle Brook NJ 133 2009.07.27 09:38 PM
Mini-z Body Database Sticky? boroEF Mini-Z Racer MR-02 4 2008.12.11 11:06 AM
Dogbreath Body Mounts How To DogbreathRacing Mini-Z Overland MV-01 6 2004.05.09 11:54 AM
Carbon Fiber Body Shells!! pukkita Parts and Hop-ups 4 2004.03.09 10:37 AM
A Tight Fitting Body... Corvette Draconious Custom Bodies 0 2001.11.26 12:43 PM
