Old 2011.08.30, 06:10 PM   #1
dgomes
Brake Trigger for EX-1, part# 16061
Hello,
Does anyone know what this is for and how it works?
Thank you in advance!
Best regards,
Daniel
dgomes is offline   Reply With Quote
Old 2011.08.31, 02:42 PM   #2
KO PROPO Staff
Originally Posted by dgomes View Post
Hello,
Best regards,
Daniel
That is the old part number for the EX-1 Mars series. The newer part number is 84006.
The new part number is reflective of the new resin material used for this part. This is the same trigger that comes on the EX-1 UR.
-Robert
Old 2011.08.31, 02:45 PM   #3
greenepa76
greenepa76's Avatar
Hi Robert,
Is the trigger assembly itself with the Potentiometer available? If so, what is the cost of the whole assembly? Mine is cracked on the throttle pin where it slips on the POT shaft.
greenepa76 is offline   Reply With Quote
Old 2011.08.31, 03:19 PM   #4
KO PROPO Staff
I have one complete EX-1 assembly available. The only thing that it does not include is the wiring that you have to solder to the pot.
This is a service item only so you would have to contact us to purchase this. The cost is $21.00 plus shipping. Once installed you have to do the Adjust Volume function to re-calibrate the pots in the transmitter.
Or you can send in the Tx for service and have it installed and the entire Tx checked over. Labor cost is $20.00 and is a flat fee for any repair performed to the Tx. This excludes parts used and shipping back to you.
Old 2011.08.31, 03:44 PM   #5
greenepa76
greenepa76's Avatar
Ok, thanks. I'm down the street from you guys. Well, about 3 miles away.
Old 2011.08.31, 04:59 PM   #6
KO PROPO Staff
Just give us a call if you want to stop by.
New Eurus 3D trigger... Chicken Little KO PROPO 6 2010.09.16 02:22 PM
Building ASC Database -- help wanted! color01 Autoscales, Bodies, Cars and Drivers 33 2010.02.19 11:59 AM
ex-1 mars re-adjust worn trigger function not working. LED KO PROPO 12 2009.06.19 06:24 PM
Vital Statistics arch2b Autoscales, Bodies, Cars and Drivers 40 2007.08.14 09:30 AM
