Old 2011.09.05, 04:24 PM   #1
Davey G
Need a mini z Painted????
Davey G's Avatar
"TWIGGY" Antenna wire
"TWIGGY" is specifically designed for the 2.4GHz ASF KYOSHO MINI Z circuit board. This antenna wire is much more flexible then the standard Antenna wire that comes with a mini z that tends to break off at the board which can make you lose control or worse damage your board. This wire has a very high wire thread count with a thin insulating jacket which makes it super flexible. Solder it on once, and you will never have to worry about your antenna breaking off. Comes in a pack of 3. Check it out!
Dave Graboski
DG Designs
Old 2011.09.05, 06:16 PM   #2
lfisminiz's Avatar
Great idea! Next job, ill take some.
Wire to replace Antenna wire?! MiamizFinest Mini-Z Racer MR-02 3 2011.06.20 10:29 PM
IW02 controller problem (antenna wire on the loose) Rokkiheebeli iWaver 4 2006.02.07 12:24 PM
Internal Antenna Ideas Teek Mini-Z Science 6 2002.07.11 10:57 AM
HELP Antenna Wire came off ESC ZeroSanity Parts and Hop-ups 4 2002.05.19 11:29 PM
Antenna wire reinforcement Mondo Setups 2 2002.01.19 11:40 AM
Copyright 2011
