Old 2011.09.21, 06:48 PM   #1
Kevin S.
Kevin S.'s Avatar
Battery Storage Discharge Rate
I currently have a Novak Smart Tray SE that I use to discharge my triple AAA's. The Novak's Discharge Current is 2.7 volts. I will not be using my AAA batteries for some time so I wanted to know what was the best cut off voltage to use for storing the batteries? Any info would be greatly appreciated...
Kevin S.
Action RC 2
Dream Killr Racing
Supporter of White Knuckle Racing
Kevin S. is offline   Reply With Quote
Old 2011.09.21, 07:56 PM   #2
chad508
chad508's Avatar
i would not discharge them if you plan to store them for a long period of time. they could end up discharging to low while being stored and be bad cells when you go to use them again. i would charge them to 1.25 volts at a low amp rating and then store them. then when you go to use them again discharge them and recharge and all should be good.
PN Racing
R1Wurks
LET's Go Racing
DG Designs
Old 2011.09.22, 10:32 AM   #3
Kevin S.
Kevin S.'s Avatar
Thanks for the quick response Chad. Would I be better off by charging them then letting them sit for 2 weeks or so and then discharging them, let them rest for a day or two and charge them up again slowly just to make sure the cells stay fresh? I don't have any problem doing that at all if that is the better option. Thanks again for your input
Kevin S.
Action RC 2
Dream Killr Racing
Old 2011.09.22, 12:51 PM   #4
chad508
chad508's Avatar
thats what i would do. but i would only discharge them at 1amp max. that way you can try and get them to hold the volts longer while sitting
PN Racing
R1Wurks
LET's Go Racing
DG Designs
Old 2011.09.22, 01:42 PM   #5
Kevin S.
Kevin S.'s Avatar
Cool, Thanks a lot for the advice Chad.
Kevin S.
Action RC 2
Dream Killr Racing
recording discharge rate without intelligence? knightrider Batteries, Chargers and Dischargers 6 2011.01.03 01:03 PM
C-9000 / BC-900 comparison shuter Batteries, Chargers and Dischargers 1 2007.05.03 12:01 AM
Another Post on Batteries: Clearing up some confusion??? Spoon Batteries, Chargers and Dischargers 21 2007.03.02 04:28 AM
