Old 2011.10.20, 04:22 AM   #1
shaggy33
Autoscale options for MR03 and motor
Can I just check a couple of things!?
1. Can any Mini Z Body (except F1 of course) fit the MR03 chassis?
2 If you fit a Wide body do you need appropriate offset wheels or can you run with other wheels and they will just be set in the wheelarches more?
3. What is the next best motor up from stock that can be run with stock fets?
Thanks for help
shaggy33 is offline   Reply With Quote
Old 2011.10.20, 06:29 AM   #2
kryten
kryten's Avatar
1.yes it can
2.you can run narrower wheels set under the body.
3.you can run a stock R on stock fets,or any of the new atomic 17mm can motors.
Old 2011.10.20, 06:38 AM   #3
shaggy33
Bodies for mr03
thank you kryten
Old 2011.10.20, 09:42 AM   #4
unearthed name
Or you can use x-speed motor
Old 2011.10.20, 09:59 AM   #5
chad508
chad508's Avatar
i would say the pn 70 are the reflex 70 would be the next step up from stock.
PN Racing
R1Wurks
LET's Go Racing
DG Designs
Old 2011.10.20, 10:59 AM   #6
Or the Atomic USA motor, which I think is 60t. ATM Stock-R is 44t, which is quite a big step up in power.
I have used just about every Mini-Z motor on stock fets. While I would recommend fets for a motor with turns less than the PN 39t, it is not really needed to use the motors. Long term use with low turn motors may slowly hurt the board...
FS: Motors, Motor Mount, FETs anarchydude Mini-Z Marketplace 27 2009.09.08 10:43 PM
Mr-03 arch2b Mini-Z Racer MR-03, MR-03 VE, Sports Series 0 2009.08.22 09:28 AM
Mini Speedway Kyosho Stock Motor Cleaning Test schmenzer Motor Tech 3 2008.02.25 12:20 AM
Tips and Tricks on the NML SSV.3 NOMOTORLIMIT Motor Tech 1 2005.02.20 03:49 PM
You can't buy the NML v3 # 8... Domenus Motor Tech 8 2005.02.20 01:12 PM
