Old 2012.08.16, 05:25 PM   #46
ub0211042
ub0211042's Avatar
Originally Posted by KO PROPO Staff View Post
If you have performed the Adjust TH (enter the function, pull full throttle, push full brake, back to neutral) and press and hold the enter button. Compete will be shown and you will be taken back to the System Menu.
If you have done this correctly and still have problems, then the throttle pot might be damaged and you should send it back to where you purchased it to get fixed or replaced.
Yes, i've did all that and still having problem...OMG have to send it back to Japan then . is this a rare case or happen to other ppl before?
Mini-Z AWD 2.4Ghz 94mm
Mini-Z MR-02 2.4Ghz
Mini-Z MR-03
FX-101 Dnano 360 Modena
Old 2012.08.16, 05:45 PM   #47
KO PROPO Staff
This is why you should purchase from your local shops (distributor) in case there is a problem.
It is rare, but can happen as nothing is perfect.
Old 2012.08.16, 06:07 PM   #48
ub0211042
ub0211042's Avatar
thanks for ur reply, lesson learned
Mini-Z MR-02 2.4Ghz
Mini-Z MR-03
Old 2012.08.31, 10:59 PM   #49
RC.DNA
A friend of mine got the exact same prob. He has it returned to local reseller and had a full refund. It's a faulty Master Unit.
RC.DNA is offline   Reply With Quote
Old 2012.08.31, 11:02 PM   #50
RC.DNA
BTW, just ship it back to Japan for a fix. Supposedly you just need to pay the shipping fees.
Old 2012.08.31, 11:39 PM   #51
ub0211042
ub0211042's Avatar
sent mine to KO Japan, they cover the shipping both ways thank god for that.
Now still in Japan and waiting for them to check whats the problem.
Mini-Z MR-02 2.4Ghz
Mini-Z MR-03
Old 2012.09.02, 12:33 AM   #52
RC.DNA
good to hear that. By the way, the problem seems not to be uncommon. In the track here, 3 out of 8 EX-1s have the same issue. It turns out that it's the grip handle that causes it and the Master Unit is fine, as at least in our 3 cases. And we notice that the packing of the grip unit is bad with inadequate protection, which might be the reason for broken grip unit during shipping.
Anyway, we have explained this to the local reseller in Hong Kong and ask them to reflect the situation to KO.
Old 2012.10.06, 03:02 AM   #53
josyskunk
I have a question about the throttle high point, for the standard 1/10 radio using mini z module, the throttle high point is set at 60%( according to KO web site) then what is the throttle high point for KIY EX1 ASF for Mini Z, does the default setting take into account that it is for Mini Z (since it is specially made for mini z only) and using the default setting (which is 100) will use the full range of ESC on the Mini Z board ?
josyskunk is offline   Reply With Quote
Old 2012.10.06, 03:11 AM   #54
ub0211042
ub0211042's Avatar
i put mine at 100...u can try pulling full throttle then hear the RPM....will peak at 100...
Mini-Z MR-02 2.4Ghz
Mini-Z MR-03
Old 2012.10.14, 12:23 PM   #55
Rune
Mini-Z Norway
Rune's Avatar
Voltage does not make a difference as the max output for FHSS is 100mW and as stated 3-3.3V is the operating voltage for a 2.4GHz chip set. 100mW is a FCC regulation for max output.
The manual says: Use batteries which have adequate remaining capacity. Weak
batteries mean lower transmitting power and may result in
malfunctions.
Does it support unregulated 7,4 lipo?
Does it have the same output power as the Euros?
Mini-Z Norway
Old 2012.10.14, 11:06 PM   #56
unearthed name
no rune. i think KIY has more power than euros right now. with Greece crisis and all.lol.
and i think it's the same between KIY and eurus.
Old 2012.10.15, 02:07 AM   #57
Rune
Mini-Z Norway
Rune's Avatar
Haha
Not easy to write the correct name...
But what you say are that the EX10 Eurus has lower transmitting power than the new EX1.
Can Ko Propo confirm this?
Mini-Z Norway
Old 2012.10.16, 05:58 PM   #58
KO PROPO Staff
malfunctions.
You can use a 2S Lipo for the EX-1 KIY, just make sure you set it to the correct battery mode being used so that you get the correct low voltage warning.
The output is the same as the Eurus due to FCC and international frequency broadcasting regulations.
Old 2012.10.17, 07:56 AM   #59
Rune
Mini-Z Norway
Rune's Avatar
Thanks a lot.
Any info on when the lipo pack are scheduled for release?
Mini-Z Norway
Old 2012.10.27, 06:58 AM   #60
machgo5go
DJ Eddie!
machgo5go's Avatar
Originally Posted by ub0211042 View Post
Hi guys,
I bought the KIY from Japan few days back, and i've encountered some BIG problem. My car runs by itself...at first i taught it was my car problem. It wasn't, its the KIY.
In the monitor view, u can actually see what each channel are doing and in my case...the TH bar flickers left and right without me holding the TH trigger.
I've tried factory reset, adjust TH, adjust trim...i works only for a while and the problem will happen again. I tried swap with my friend's Hand unit and it works flawlessly.
Hope someone can shed some light on this, thanks!
http://www.youtube.com/watch?v=G1nLZScXfpI
KO Propo America took care of it under warranty in faulty Trigger repair service & Great turnaround time also.
MR-03 Mclaren MP-12CGT3 AT70T
MR-03 S2K Narrow AT60T Nihm
MR-03 BRZ Narrow PN70T Nihm
AMZ Benz TC 8500KV
X Power IDT Ultra 5600KV Audi
X Power IMT Ultra 6800KV M3
214 State St. Suite 209
DG DESIGNS
machgo5go is offline   Reply With Quote
***For Sale: *KO Propo Radio * KO ProPo Mini Z Module *** nugget Mini-Z Marketplace 4 2010.07.29 08:16 AM
ko propo ex-1 mars radio fs bobbyz Mini-Z Marketplace 2 2010.07.19 01:58 AM
FS: Ko Propo EX-I UR radio with upgrades and LIPO davskee Mini-Z Marketplace 3 2009.11.02 04:37 PM
FS: KO Propo EX1-UR with Kyosho radio case reechaard Mini-Z Marketplace 5 2008.11.16 02:11 AM
FS: Ko Propo Mars R radio for Mini-Z - $150 pchan0 Miscellaneous Discussion 0 2003.08.25 04:52 PM
