Old 2012.01.18, 10:09 AM   #1
BlackBerry
MR03 Low Profile Front Suspension Question
Do I need to ream the lower ball joints on the PN Aluminum lower arm to properly seat the lower delrin balls of this kit?
I had to do it with my stock kyosho lower arms as there was too much friction without modification, wondering if its the same deal with aluminum arms. Hope not.
Thanks,
BlackBerry
BlackBerry is offline   Reply With Quote
Old 2012.01.18, 10:47 AM   #2
CristianTabush
CristianTabush's Avatar
You should not need to ream them out. However, sometimes, there is a bit of an edge on the balls so after you insert them in the slot, you might need to use a tool to pry them and rotate them inside the cup. Once inside, it should be smooth.
Cristian Tabush
REFLEX RACING USA
http://www.reflexracing net
Old 2012.01.18, 11:15 AM   #3
chad508
chad508's Avatar
i lso used some of the reflex white stuff to help polish the ball and alum arm once the ball has been installed. just make sure to clean it out real well as to not over sand and cause slop.
PN Racing
R1Wurks
LET's Go Racing
DG Designs
Old 2012.01.18, 02:55 PM   #4
JuniorWKR
White Knuckle Racing
JuniorWKR's Avatar
i also have always just used a small amount of the reflex white stuff in any manufatures combo and it always works great...
Junior
Old 2012.01.18, 08:23 PM   #5
BlackBerry
Thanks for the quick replies. I was hoping it wouldn't need any reaming .
BlackBerry
Old 2013.01.30, 06:37 AM   #6
RobbyDV
Some 'low profile front suspension kit' questions
Just bought a low profile front suspension kit, the soft spring set, the reflexR low profile knuckles and the REFLEX RACING MR-03 DELRIN FRONT UPPER ARMS. All the other parts are standard kyosho. Here are some questions:
- regarding the optional soft spring set:
These springs are 90g and 110g springs to complement the silver (130g and gold 150g) springs that come in the low profile front suspension kit. The 90g work great on bumpy tracks and the 110g are awesome for those that feel the silver is too stiff.
... So which color for the 90 and which color for the 110 g spring (the 2 colors in the soft spring set are greenish gold and silver)
- what is the value of the black spring (70g?)
- how many mm of spacers below/above the knuckle and above the arm to start with (mild steering setting), using 23-23.5 mm wheels and the standard kyosho
RobbyDV is offline   Reply With Quote
Old 2013.01.30, 09:16 AM   #7
Rune
Mini-Z Norway
Rune's Avatar
- regarding the optional soft spring set: ... So which color for the 90 and which color for the 110 g spring (the 2 colors in the soft spring set are greenish gold and silver)
Gold=90
Silver=110
Dont know exactely. It is very soft. Too soft for anything i have tried them on.
The arms should be straight or angled up slightly on the outside. More angle to the outside will increase camber gain. If you are struggling for front grip, increase the angle.
Try 2mm below knuckle. 0 between arm and knuckle. Add shim to increase angle of the arm.
Spacers on top of the arm are used for preload settings. A good starting point is slight preload so that you get close to zero droop.
Mini-Z Norway
Old 2013.01.30, 10:45 AM   #8
RobbyDV
Ok, thx for the swift response
Old 2013.01.30, 12:50 PM   #9
CristianTabush
The black springs are not even usable. Don't worry about those. When we got them made, they just made them too soft.
The soft spring set, to be able to tell which is softer, just look at whichever spring has more coils. In this case, it's silver.
Cristian Tabush
REFLEX RACING USA
Old 2013.01.31, 05:14 AM   #10
Rune
Mini-Z Norway
Rune's Avatar
The black springs are perfect for saving the dogbones on the Buggy though
Place them in the diff cups, and you are set.
Mini-Z Norway
Old 2013.01.31, 06:55 AM   #11
picture of this?
Old 2013.01.31, 11:03 AM   #12
Rune
Mini-Z Norway
Rune's Avatar
Not at the moment sorry. I will see if I can take one at the track later.
Works like a charm for the dog bones in the front. The springs will push the bones out, and make sure they dont strip to the extent they usually do.
The hardness are perfect, and doesnt add tension to the suspension.
Made this illustration to show where to add the springs. Do this on both sides of the diff before inserting the dogbone.
Mini-Z Norway
Brian's RCX 2011 Final Setup color01 Mini-Z Racer MR-03, MR-03 VE, Sports Series 35 2017.02.19 06:38 PM
About tweak and how to perfect balance your 4wd suspension. eztuner12 Mini-Z AWD MA-010, MA-015 7 2011.04.15 03:56 PM
MR03 Double A-Arm Front Suspension, when will be avaliable? machgo5go PN Racing 4 2010.06.07 11:54 PM
Front suspension PorscheGuy964 Parts and Hop-ups 2 2001.12.30 03:49 PM
front suspension budwilson Setups 12 2001.11.11 04:52 PM
