Old 2002.08.05, 12:24 AM   #1
ScottMcLeod
Send a message via ICQ to ScottMcLeod Send a message via AIM to ScottMcLeod Send a message via Yahoo to ScottMcLeod
Simple FET Question
I need full specs on the stock FETs, and the upgraded FETs... (/me is going on a FET hunt)
-Scott
ScottMcLeod is offline   Reply With Quote
Old 2002.08.05, 01:52 AM   #2
BJS-TF
Mini-Z Pro
Send a message via ICQ to BJS-TF
3004
BJS-TF is offline   Reply With Quote
Old 2002.08.05, 02:43 AM   #3
W-tone
IRF7389
W-t
"Jazz is not dead, it just smells funny..."
W-tone is offline   Reply With Quote
Old 2002.08.05, 09:22 PM   #4
Wedginator
where can i buy these? and how much?
Old 2002.08.07, 06:56 PM   #5
ianc
ianc's Avatar
Hmmm... That's all very nice, but I have no idea what I'm actually looking at here...
Is the Continuous N-Channel Drain Current rating what we're looking for to avoid frying the ESC's? If so, I see:
3004: 5.5 A
IRf7389: 7.3 A
What is the key parameter here?
ianc
Old 2002.08.07, 07:13 PM   #6
ultrawide
Same same, but different.
Is 3004 not the one pre-installed in the mini-z? Would I gain anything double it with another one then?
ultrawide is offline   Reply With Quote
Old 2002.08.07, 07:22 PM   #7
ianc
ianc's Avatar
Hi Ultrawide,
Yes, the 3004 is factory installed in the Z.
I believe the purpose of the turbo is two fold:
1) To lower the internal resistance of the FET's so that a higher voltage reaches the motor, giving better performance, and
2) To increase the current rating of the ESC so that hotter motors can be used.
I think both of these objectives would be met by piggybacking an additonal 3004 on top of the originals, but the IRF7389 has both less resistance and a higher current rating than the original 3004, so this would be preferred...
ianc
Old 2002.08.07, 07:26 PM   #8
ultrawide
ianc
Any idea if it will work with 3006 instead in the piggyback, above the 3004?
Old 2002.08.08, 05:39 AM   #9
ianc
ianc's Avatar
Hi Ultrawide,
I have no idea whether a 3006 will work I'm afraid. I don't know whether it's pin-compatible, or any of the specifications. I'm quite light on electrical engineering. I was a mechanical engineering major in college ten years ago and regarded the few EE courses they made us take as voodoo... Forgot just about all of what little I knew...
ianc
Old 2002.08.08, 07:03 AM   #10
Rossen
Mini-Z Novice
Send a message via ICQ to Rossen
Hey ultrawide,
The IRf7389 can be bought at Elfa.se, just do a search for IRf7389 and you will find it. If you do this mod you'll have to get at least four, preferably eight FET's so it isn't economicaly defendable to get an internal turbo, at least not in Sweden
Rossen is offline   Reply With Quote
Old 2002.08.08, 07:16 AM   #11
W-tone
I do not know how much a turbo costs in sweden but my mod of 4 irf7389 cost me approx 25e and is well worth it. If Elfa is expensive try your local RS distributor.
HAT3006r is a pin compatible replacement and seems like a good upgrade to the 3004.
The IRF part is marginally better.
Key parameters are the Rds(on) resistance and max current capacity, smaller of the two values(P or N channel) is to be considered the limit.
W-t
Old 2002.08.08, 08:02 AM   #12
ianc
ianc's Avatar
Thanks W-Tone! Then we can say for max current capability:
3004 (stock): 3.5 A
3006: 4.5 A
IRF7389: 5.3 A
If two FET's were piggybacked, would that result in a theoretical doubling of the current capacity?
I forget the relation for two resistances in parallel. Isn't it:
Rtot = (R1 + R2)/(R1 * R2)?
ianc
Old 2002.08.08, 08:51 AM   #13
W-tone
The notation I'm accustomed to is:
1/Rtot=(1/R1)+(1/R2)
Effectively the resitance is halved when connecting identical resistances in parallel. Also the max current is doubled. Well.. in theory it is doubled, there may be some deviation if the FETs are not identical.
Within normal tolerances I think the devation can be ignored.
W-t
Old 2002.08.08, 12:40 PM   #14
BJS-TF
Mini-Z Pro
Dear all,
I'm from HK. I want to ask is their any R/C shop/Technical people to install the FET or Change the FET DIY?
Regards,
TungFai
from Hong Kong
Old 2002.08.23, 04:16 AM   #15
greetings bjs-tf...
not many people know how to changes fets over here... i had somebody do mine... it works fine... can you please teach us?
herman is online now   Reply With Quote
Fet question for fet-techs? xxam Mini-Z Science 2 2008.04.03 10:48 AM
Mini-z steering FET Question (read this ByeBye) CUSTOM Miscellaneous Discussion 6 2007.10.08 10:38 PM
Question about the stock fet aimfox Mini-Z AWD MA-010, MA-015 2 2007.08.30 07:29 PM
Fet question that has not been answered yet Dustin Mini-Z Science 4 2005.04.01 01:31 PM
burnt fet question BoyWonder Parts and Hop-ups 8 2003.07.17 12:38 AM
