Go Back   Mini-ZRacer.com Forums > Manufacturers > X-Power R/C
Old 2012.06.28, 12:19 PM   #16
twinkie
Originally Posted by mleemor60 View Post
You are correct. However the Reflex piece lacks the utility of being able to mount say a 94/98mm DPS in the 102mm position. Or vice versa. As I said before. One of these in your tool box could be used as an emergency replacement for a broken or damaged top cover.
I agree with you there
twinkie is offline   Reply With Quote
Old 2012.06.28, 03:12 PM   #17
hrdrvr
hrdrvr's Avatar
Also, they never show the bottom of the plate. the more I think about it, the more I think it can be more friendly than I originally thought. If the bottom of the slots have tapered edges, and notches for a countersunk screw, you could feasibly adjust them by just loosening the lock nuts, moving it, then re-tightening them, with the notches in the bottom guiding the countersunk screw into the proper location. This would also keep the tightened down screw from sliding fore/aft in a collision. If the three holes in the front are tapped, then you could just mount the top shock to the 'Y"piece, then screw through the exposed "Y" piece hole, into the desired top cover hole (depending on what length you are looking for. You would be able to move the entire top damper set up with just loosening two nuts, and removing one screw. They just need it in 2mm adjustments so we can still use out RR 96mm plates
If the top cover is designed like this, two thumbs up, if not, I guess I've given you a good look at where the evolution of the part could head
Landon
LET's Go Racing!
Old 2012.06.28, 04:22 PM   #18
twinkie
wished it was tapped...had the same thoughts as you.
Old 2012.06.28, 06:49 PM   #19
hrdrvr
hrdrvr's Avatar
I just looked back, and the 102 pics make it looked like those front holes are threaded. Might look a little stripped, but possibly threaded.
Landon
LET's Go Racing!
Old 2012.06.28, 07:13 PM   #20
the bashing gets us no where. no one wins in those kind of fights.
i hope it's threaded to, if not, the next batch should be i have a reflex cover myself that i'm more than happy with but added adjustability is a plus provided it doesn't come at the expense of steadfastness and precision. i'll let someone be the early adopter on this one and see how it performs.
Old 2012.06.28, 07:16 PM   #21
chad508
chad508's Avatar
why not just slot the damper plate and have it slide on the post? it would be a lot more user friendly. i have always drilled my top plates the mount the shock to instead of using the y piece, i run a screw up from the bottom then a nut and shim as needed to get the shock at the right height
PN Racing
R1Wurks
LET's Go Racing
DG Designs
Old 2012.06.28, 09:04 PM   #22
hrdrvr
hrdrvr's Avatar
What happens when you move your pod back Chad?
Landon
LET's Go Racing!
Old 2012.06.28, 10:22 PM   #23
chad508
chad508's Avatar
i never move my pods, i just grab a new chassis. plus why would you run anything longer than 96 anyways.
PN Racing
R1Wurks
LET's Go Racing
DG Designs
Old 2012.07.08, 09:39 PM   #24
XPowerRC
Originally Posted by hrdrvr View Post
Do you have to take the top cover off to change wheel bases? It looks like it is screwed up through the bottom of the top cover.
There is no need to take off the top cover for the change of the length.
XPowerRC is offline   Reply With Quote
