I figured I would post this since I seem to be the only person who can successfully use Model Masters. I did these bodies fast since I had to do 3 before the KO race. I usually take my time and it takes about a week, but this time I had to chance/rush the cure time and do it in three days.
First off I like it due to it being Lacquer nice and thick, and is easy to work with.
So here we go.
Things you will need:
1.Clean Work Area
2.Denatured Alcohol
3. Tamiya Masking Tape (could be another brand I just prefer Tamiya)
And a blue painters tape.
Step 2. Wash the body using luke warm water. I just use hand soap. The goal is to remove any oil(s) that could be on the body that would cause fish eye. And to remove any contaminants that can cause the paint to lift. (note: I usually where latex gloves but this is a demo pic)
Step 3. Whipe the body with denatured alcohol. Again removes oil, and moisture.
Step 4. Just gently swipe the body with the tack rag to remove any dust or small lint from the body.
Then I use the blue tape to cover more area faster. Remember to overlap at least half the tapes width. You get two things better adhesion, and if the color bleeds, it wont travel as far.
Now I am painting three different bodies so the colors may be different in the pictures. But all three bodies have the same design.
I use a cardboard box for a booth that I have been using for months now.
I take a damp towel and wipe down the box and my work area. It removes the dust, and will help keep the dust down when shooting.
Make your first come of coats light, wait about two minutes the paint will start to get tacky. Put down a heavier coat, wait about 4-5 min, then hit it with a nice coat. The heavy top coat should remove a lot of the orange peel. That technique takes time and trial and error on how fast to move the spray.
After about a couple of hours to 24 hours, go ahead and remove the masking. Remember that if the masking is removed to early the edges of the paint will pull up giving you an uneven. If the paint is soft enough you can lightly push it back down ( i don't recommend it but I did it during this rush job).
Notice how it bled through, but because the tape was overlapped halfway I don't have to worry about the body. Now if you do get a portion that ran through, don't worry. If it is just a mist, take your rag with denatured alcohol and just wipe the paint away.
Now I typically wait 24hours before applying my next stage of masking. You spend so much time prepping and everything its would suck to have your tape removing paint.
Now to get a clean mask in some areas like the nose of the car I will take a SHARP exacto blade cut the tape to the body line.
Remember when wiping with the denatured alcohol be gentle, and do not wash it down. very light and very very little pressure. The denatured alcohol will remove the paint.
ok now the cans say that it can be cleared after 2 hours... me personally I wait 24 hours. I want to make sure I am no where near that flash time. Flash time is the time where the chemicals are being released from the paint and the paint is drying/adhering itself to the part. If you spray during the flash time, the paint will lift, crack, bubble, just be ugly.
With the clear again, a couple light coats then just hit it. The part should just look "wet".
Here is what model masters paint clear will look. The rear deck lid is nice, deep and wet looking. The roof and the hood is a light color so not much depth but its also a metallic.
My girlfriends car for the KO Propo Grand Prix. We didn't have time to paint the rear pillars. But you can see the metallic pearl in the silver in this picture.
Also didn't have time to wax it...will be doing that this weekend.
