Old 2012.07.15, 07:02 PM   #16
lfisminiz
lfisminiz's Avatar
OK, im ready for one!
Old 2012.07.15, 07:15 PM   #17
Come on Larry. Just one? I want at least two and more likely three.
Old 2012.07.15, 07:51 PM   #18
lfisminiz
lfisminiz's Avatar
Well...i would like it in 94 and 98...maybe LM too.
Old 2012.07.21, 02:55 PM   #19
Fovea3d
Fovea3d's Avatar
Prototype finished. I ran out of red so I changed color.
I still need to edit the 3d model for production.
3d printed bodies and parts
mini6z
European mini-z forum
My mini-z collection
Old 2012.07.21, 11:52 PM   #20
leonabi76
Super nice! I will most def have to get this one. I just now learning how Shapeways materials work. I keep forgetting the minimum thickness requirements for each material. Good stuff. Keep up the great work!
leonabi76 is offline   Reply With Quote
Old 2012.07.23, 03:33 AM   #21
akura2
PROFESSOR TRUTH JIMMY ICE
akura2's Avatar
Send a message via Skype™ to akura2
Zcuderia... that looks awesome!!
I can see where it does need to be fixed a little though... where it looks like it's rubbing the backs of the rear tires and the front right.... nothing a little creative dremeling couldn't fix though....
akura2 is offline   Reply With Quote
Old 2012.07.23, 03:38 AM   #22
well done... super like...
Old 2012.07.23, 05:27 AM   #23
Fovea3d
Fovea3d's Avatar
I can see where it does need to be fixed a little though... where it looks like it's rubbing the backs of the rear tires and the front right.... nothing a little creating dremeling couldn't fix though....
Spot on Strange because the wheelbase is really 102mm on the 3d model.
This will be corrected for production.
Forget Dr Emel on White Strong and Flexible. You cant... The Nylon will heat then melt, and make strands before the material cuts.
White strong and flexible really is STRONG
mini6z
Old 2012.07.23, 05:34 AM   #24
Fovea3d
Fovea3d's Avatar
Thanks! Minimum wall thickness for White Strong an Flexible is 0.7mm.
0.8mm is ideal for MZ bodies. but you need to make ribs for rigidity around the body mounts and in the nose.
Due to a new rule at Shapeways some models longer than 12 cm may be rejected for print with 0.8 mm wall thickness, they want them over 1mm at that size (and I'm not so happy with that > all my prototypes were printed correctly with 0.8mm).
mini6z
24 Hours of Le Mans = 24% off AutoScales!!! Mrs Mini-Z Promotions 1 2010.06.12 11:19 AM
new Le Mans mini z piper1944 Parts and Hop-ups 10 2008.01.06 01:41 AM
