Old 2012.07.16, 04:52 PM   #1
pinwc4
pinwc4's Avatar
Flip Side Racing 12.09 available
A new version of Flip Side Racing software has been posted for download on http://www.flipsideracing.org/
This is a small update focused on bug fixes. There is 1 new feature of interest to Mac users, the ability to use the full screen application mode that Lion introduced.
Below is a list of the other changes this build brings.
New Features
  • Software now supports the Full Screen mode in Mac OS X Lion
Changes
  • Adjusted sensitivity for Giro-Z, hopefully minimizes the amount of false hits detected
Bug Fixes
  • Fixed bug that occurs if you unplug a USB device after launching the software and then select the last COM port in the list on the General Config. screen
  • Added logic so that if a corrupt image is scaled the program will show a white image instead of giving an error
  • Added logic to prevent error if a race is selected on the statistics screen that has been manually deleted out of the database using a third party program
  • Removed error that would occur if you attempted to access documentation but had no documentation folder
  • Removed error that would occur if the club logo folder did not exist and you attempted to send a test email
Old 2012.07.16, 05:03 PM   #2
to clarify, is this a version i've already tried with Giro-Z unofficially? if not, i'll give this a try for practice rounds to see if the counting is accurate this time around. The call out features with flipside are missed by my club with zround.
just checking but does driver with fastest lap get designated by a special color? we really find it useful that the TQ driver is distinguished by color in zround making it easy to immediately identify the driver.
Old 2012.07.16, 05:58 PM   #3
pinwc4
pinwc4's Avatar
This has some new changes that were not in the prior version for Giro-Z. I am hoping to this change will minimize false detections.
No, not at the moment. I am not familiar with what zround is doing. Is this something that is done as part of the race report after a race is completed or is the racer highlighted differently during a race?
Old 2012.07.16, 06:47 PM   #4
during a race or practice session, the driver with the fastest lap stays a highlighted color. it's just a visual cue that makes it easy to pick them out on the screen.
i'll download and get this version on our track computer to test. next race day is Aug. 11th. but i'll try to get something in before then.
Old 2012.07.18, 12:52 PM   #5
pinwc4
pinwc4's Avatar
I am not sure this would work out well with Flip Side. As is each racer has a different color on the race screen. Changing the color of racers throughout a race seems like it would be confusing. I am guessing that Zround probably does not color each racer instead having the same color for everyone except the fastest lap? That would make it easy to identify the fast lap but I have always liked having the different colors for racers to make it easy to identify specific racers on the screen.
What are your thoughts?
Old 2012.07.18, 01:15 PM   #6
i believe you can configure individual racer text color however default is they are all the same.
my guys like being able to easily see the fastest driver vs. knowing to look for their specific color. maybe this could be a theme or option to configure vs. implementing the same thing on flipside. doesn't have to be driver text color, you could highlight the text regardless of color or indicate with an icon of some sort. it's just a convenient feature we found and like.
it's also worth noting that this is displayed on the secondary monitor screen that the drivers/public see's vs. the race manager screen i work with however flipside uses only one screen unles you clone the display view. i'm sure when you get to race management, you'll have something similar.
Old 2012.07.18, 08:38 PM   #7
pinwc4
pinwc4's Avatar
Yeah, maybe some other highlighting would work better in this case. Though I could just make it a color you enable and define. I will give it some thought but it will not be something that makes it into the next release.
I have been doing a lot of work towards this recently, and unlike my prior race manager work I do not think I am going to throw this code out because I do not like it.
However in order to get this out to people sooner the initial releases of the race manager will not have a secondary screen. I am just going to focus on getting a basic integrated race manager done and out to people. At this point I am probably going to put a hold on any new features until I get the basic race manager done.
Old 2012.07.18, 09:07 PM   #8
understood. as always, thanks for the hard work and producing a program we enjoy using very much.
Old 2012.07.20, 03:46 PM   #9
pinwc4
pinwc4's Avatar
Here is a quick screenshot of the current state. Still a lot of work to go to make it fully functional but I have made good progress over the past few weeks.
Old 2012.09.16, 09:28 AM   #10
somewhere along the line i had forgotten to run this check on giro-z. i've downloaded again and will run it next time i get to a track.
can you remind me how you create a new driver with giro-z? they don't pick up by default like core. at least they did not this weekend when i tried to run 12.11.
Old 2012.09.16, 09:38 AM   #11
pinwc4
pinwc4's Avatar
With the Giro-Z you should be able to click the Scan button and then pass a transponder under the bridge. I think you have to do this within 10 seconds or the scanning operation times out and you would have to click Scan again to start a scan. You do not want to have the transponder under the bridge until after you click scan.
Old 2012.09.16, 09:47 AM   #12
thanks, i'll run this one again.
Version 0.64 of Flip Side Racing software available pinwc4 Flip Side 3 2011.06.28 10:38 PM
Version 0.59 of Flip Side Racing software available pinwc4 Flip Side 0 2011.04.21 12:20 PM
Version 0.43 of Flip Side Racing Software now available pinwc4 Flip Side 31 2010.03.16 09:19 PM
Version 0.41 of Flip Side Racing Software pinwc4 Flip Side 8 2010.02.09 04:34 PM
Version 0.40 of Flip Side Racing Software now available pinwc4 Flip Side 4 2010.02.08 07:53 PM
