Old 2012.08.19, 05:48 PM   #1
cowboysir
Helios with steering balance problem
Hello,
I have a minor issue with one of my spare radios. It is an EX10 Helios and it has an issue with adjusting the steering balance. When you turn the wheel to pick a direction to adjust the balance one direction (left I think) doesn't register.
While its not a huge concern, one of the cars I use (MR02 with an 03 board) requires programming a higher steering balance percentage so with one direction stuck at 70% I have to set the steering travel to 140 to get a full lock in both directions.
Is this a problem or have I figured out a suitable solution without having the balance setting?
Old 2012.08.21, 01:46 PM   #2
KO PROPO Staff
Perform the Adjust VR function. You have to finish both the steering (ST) and the throttle (TH) sets for the settings to take effect. If you cannot finish either step of the function, then the pot is damaged and will need to be serviced.
Old 2012.08.21, 03:00 PM   #3
briankstan
SLMZ / HFAY
briankstan's Avatar
thanks for the info, one of our racers is having this issue as well.
Old 2012.08.21, 11:14 PM   #4
cowboysir
adjust VR recalibration worked like a charm....i now get steering balance adjustment both left and right!
Thanks so much, KO!
МА-010 with MR-03 board - steering travel problem Bodom Mini-Z AWD MA-010, MA-015 35 2012.03.15 09:39 PM
2.4GHz Steering problem rcmorris 2.4GHz ASF System (Auto Selected Frequency) 3 2008.08.10 11:13 AM
Problem with steering Migiagi Transmitters, Receivers and Crystals 3 2008.08.07 01:46 PM
Another Steering Problem... carfreak_22 Mini-Z Monster MM-01 18 2005.04.08 11:51 AM
Steering Centering problem on MR02 melvin Mini-Z Racer MR-02 3 2004.04.14 06:23 AM
